dyno results done!
Old Sep 9, 2003 | 07:57 PM
Mr. Softee's Avatar
Default dyno results done!
setup:
b18a stock head
10:1
uberdata
tinker's equal length mani
t3/t4 57 trim stage V wheel .63
254whp
233wtrq
only did 6 runs. It runs like 11.5:1 above 6 grand, and im taking out a lot of timing. This was at 10-11psi. I could have probably made 270 with race gas and more timing and running leaner but im pretty damn happy how it is right now.
i will post screenshots of my rom files / a/f ratio / graph later!
sam
Old Sep 9, 2003 | 07:58 PM
Tinker219's Avatar
Default Re: dyno results done! (94goldjungsr)
turn up the BOOST
SiRkid's Avatar
nice..thats some good torque..
what motor(judging by name i say gsr but who the heck knows these days)
Old Sep 9, 2003 | 07:59 PM
TotalJDM.com's Avatar
Those are some really not bad numbers! You got a bad *** manifold too!
Andre
Old Sep 9, 2003 | 08:01 PM
Mr. Softee's Avatar
Default Re: dyno results done! (Tinker219)
in response to tinker's turn it up comment-
hehe i will
Old Sep 9, 2003 | 08:28 PM
shermanyang's Avatar
nice numbers!! now take it to the track before the year is over!! post up the graph too i would like to compare charts with you.
Old Sep 9, 2003 | 08:30 PM
Mr. Softee's Avatar
Default Re: dyno results done! (shermanyang)
what psi were you at?
Old Sep 9, 2003 | 08:38 PM
T4eg's Avatar
NICE
Old Sep 9, 2003 | 08:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">what psi were you at?</TD></TR></TABLE>
if you're asking me....i was at 15 psi on low compression pistons. i think you'd make more power than me if you boosted the same amount i'm boosting since you've got higher compression.
Old Sep 9, 2003 | 08:46 PM
Mr. Softee's Avatar
probably.
Old Sep 9, 2003 | 09:03 PM
LsTurbo91's Avatar
How much timing did you remove and what was the initial timing set at?
Old Sep 9, 2003 | 09:38 PM
Mr. Softee's Avatar
Default Re: dyno results done! (LsTurbo91)
im at like .5 degree per # taken out
sheet
i settled out some of those top end issues a litttle bit by leaning it out so ignore that little cup type thing.
sam
Old Sep 9, 2003 | 09:42 PM
your torque curve is almost identical to mine...damn!! i wonder if it's due to the equal length mani? other people's torque curves that i've seen kept climbing...but weren't as high. i wonder....
Old Sep 9, 2003 | 10:12 PM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">your torque curve is almost identical to mine...damn!! i wonder if it's due to the equal length mani? other people's torque curves that i've seen kept climbing...but weren't as high. i wonder.... </TD></TR></TABLE>
Hes only got 3 of 4 bolts holding the turbo to the manifold, I suspect this has something to do with it(leaking before the turbo)...
Old Sep 9, 2003 | 10:21 PM
Drew Peacock's Avatar
Perhaps you have reached the peak flow rate for the B18b head?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">
Hes only got 3 of 4 bolts holding the turbo to the manifold, I suspect this has something to do with it(leaking before the turbo)...</TD></TR></TABLE>
Old Sep 10, 2003 | 01:28 AM
Full-Race Henry's Avatar
Did you take it to apex in tucson to get it dynoed?? Did you let Mikey tune it? nice torque #'s. you gonna run it this weekend at speedworld?
Old Sep 10, 2003 | 08:16 AM
AzG35's Avatar
Default Re: dyno results done! (EF8_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan &raquo;</TD></TR><TR><TD CLASS="quote">Did you take it to apex in tucson to get it dynoed?? Did you let Mikey tune it? nice torque #'s. you gonna run it this weekend at speedworld?</TD></TR></TABLE>
Mikey did the running, Sam did the tuning with the aid of the FJO. Good numbers, I was impressed.
Old Sep 10, 2003 | 08:40 AM
Default Re: dyno results done! (AzSi22)
Pretty good, I wouldn't be too disapointed of those numbers or anything!
Andre
Old Sep 10, 2003 | 09:21 AM
Default Re: dyno results done! (TotalBoost)
whats fuel setup are you using?? you gonna take it to speedworld this weekend?
Old Sep 10, 2003 | 03:03 PM
Mr. Softee's Avatar
i have dsm 450s, a walbro 255, a b&m adjustable and inline resistors. stock rail/lines.
my uberdata map is REDICULOUS. im at 1300 in some areas for my fuel values.
tuned the car msyelf and will be running it soon! drives real nice on the street
sam
Old Sep 10, 2003 | 04:39 PM
Overblown-Teg's Avatar
Can you post up a screen shot of your map? fuel and ignition..
Old Sep 10, 2003 | 07:32 PM
Mr. Softee's Avatar
Default Re: dyno results done! (Overblown-Teg)
later in the week i will the computer w/ the files isnt online
sam
Old Sep 18, 2003 | 06:48 PM
Mr. Softee's Avatar
heres my before and after uberdata fuel charts
2nd one is after.
Old Sep 18, 2003 | 07:58 PM
tegasaurus's Avatar
lotttta fuel goin in that motor! when do i get a ride? this weekend i hope...
1SlowSi
Mar 6, 2009 12:43 PM
mrchris1979
Jan 12, 2008 03:45 AM
ELSpool
Aug 2, 2006 04:51 AM
anothaRRR
Apr 29, 2005 04:30 AM
phiberoptik
Sep 30, 2004 07:20 PM
