Dyno and compression results???
Old May 21, 2006 | 01:50 PM
slodel's Avatar
Default Dyno and compression results???
heres my setup
d16z6 177,000 miles
jg performer mani
3 inch downpipe
top mount mani
t04 .60 aireasearch turbo, tuner said it was a slow spollin turbo spools about 3700-4000
hondata s200
2.5 exhaust
440 rcs
arp head sutds
new head gasket
ok heres the number 120whp 119trq
compression 145 to 150 on all cyl are these normal numbers???
the fuel pump starts to give out at high rpms and it needs a stock fuel pressure regulator
the fuel problems are the reason he did not tune it any higher
but my question is?? Is the other reason the numbers could be or are low because the compression
Would a smaller turbo help out any???
should i spring for pistons and rods???
i am just looking to get in the 12s id be happy with anything about 230whp???
i am stuck guys help me out
thanks
hope i didnt forget anything thanks
Old May 21, 2006 | 02:32 PM
slodel's Avatar
Default Re: Dyno and compression results??? (slodel)
22 veiws but no anwsers i must be in a pickle
BUMP
Old May 21, 2006 | 04:54 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
pistons, rods and a medium-sized T3/T4.
Old May 21, 2006 | 04:57 PM
Zakar's Avatar
your comp is low.. how much boost were you running? who did the tuning?
that turbo is way big for that engine..
Old May 21, 2006 | 05:44 PM
slodel's Avatar
Default Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">your comp is low.. how much boost were you running? who did the tuning?
that turbo is way big for that engine..</TD></TR></TABLE>
the most boost i ever run is 9lbs
so you think get a rebuild?? The numbers are close together i thought consistency is key???
RS Motors did the tuning very nice people
thanks guys for the replys
Old May 21, 2006 | 05:53 PM
drintegra's Avatar
Default Re: (slodel)
were yoir compression tests run on a warm motor?
when you say 120hp, was that on 9psi, cause there is something wrong?
when you say tune, with waht exactly?
your motor reads low, or the test was not performed right. My z6 has 225XXX and at 160000 it pulled 185 across the board. I milled the head and have a zex cam and 220 across all cylinders. You may need a rebuild, good luck.
Old May 21, 2006 | 06:45 PM
GaRn's Avatar
Default Re: (drintegra)
I would recommend ditching the turbo you have (sell it) and going with a 60 trim t3... that will get you 230 whp no problem..
that turbo is quite large and is no doubt your problem.
Old May 21, 2006 | 06:49 PM
AbitAvenger's Avatar
Default Re: (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra &raquo;</TD></TR><TR><TD CLASS="quote">were yoir compression tests run on a warm motor?
your motor reads low, or the test was not performed right. My z6 has 225XXX and at 160000 it pulled 185 across the board. I milled the head and have a zex cam and 220 across all cylinders. You may need a rebuild, good luck. </TD></TR></TABLE> mine with 200k pulled 180 across
What boost was this at?
Also get an aftermarket fuel pump
Old May 21, 2006 | 08:06 PM
slodel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend ditching the turbo you have (sell it) and going with a 60 trim t3... that will get you 230 whp no problem..
that turbo is quite large and is no doubt your problem.</TD></TR></TABLE>
that problem is solved then thanks
yeah the motor was warm
it was tuned at 6lbs at 120 to the wheels
tuned on hondata
is anyone running a stock fuel pump at 200 to 250 whp?????
thanks guys
Old May 22, 2006 | 07:04 AM
slodel's Avatar
any more opinions???
Old May 22, 2006 | 07:58 AM
SOHC_MShue's Avatar
sounds like something is wrong with your motor or setup. When you did the compression test was the throttle held wide open?
Old May 22, 2006 | 08:23 AM
slodel's Avatar
Default Re: Dyno and compression results??? (SOHC_MShue)
i will do the test one more time on a cold motor and throttle held wide open and with all the plugs out and see what happens before i take it in for new pistons and rods and turbo and turbo manifold
thanks guys
Old May 22, 2006 | 09:22 AM
yee SERIOUS's Avatar
your compression is a bit low, but i don't think i'd worry about it too much personally. i'd recommend you get a t3 super 60. i have no idea why you have a t4 turbo. unless you meant to say td04? also get a walbro fuel pump and b&m fpr at least.
what do you think happens when you have more air going in at a faster rate and you don't have enough fuel to compensate for it? you better take care of that fuel pump problem.
Old May 22, 2006 | 09:47 AM
slodel's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">your compression is a bit low, but i don't think i'd worry about it too much personally. i'd recommend you get a t3 super 60. i have no idea why you have a t4 turbo. unless you meant to say td04? also get a walbro fuel pump and b&m fpr at least.
what do you think happens when you have more air going in at a faster rate and you don't have enough fuel to compensate for it? you better take care of that fuel pump problem.</TD></TR></TABLE>
so you dont think pistons and rods are neccessary right now??? is a t04 .60 turbo its a big turbo now for sale with a custom top mount
i am getting a fuel pump and already have a FPR but i hear stock FPR is better??
i am for sure getting a smaller turbo and new manifold
thanks for the info guys the more comments and help the better it will be
Old May 22, 2006 | 01:37 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">i will do the test one more time on a cold motor and throttle held wide open and with all the plugs out and see what happens before i take it in for new pistons and rods and turbo and turbo manifold
thanks guys </TD></TR></TABLE>
no it has to be a warm motor.
Old May 22, 2006 | 02:01 PM
slodel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
no it has to be a warm motor.</TD></TR></TABLE>
ok it was originally
Old May 22, 2006 | 02:08 PM
mrmonty17's Avatar
Your numbers may not be low. The same engine compression tested in a different locations may yeild different numbers. There are all sorts of variables that can effect a compresion test. Such as how many times start cycles you are running. My best suggestion would be to say bump compression testing and have it a Leak Down test run. Are you getting alot of blow by?
duck22krazy
Nov 12, 2008 11:59 PM
nah22accord
Feb 2, 2006 07:57 PM
vaporboy12
Feb 3, 2004 07:14 PM
Ideal
Jan 2, 2004 12:12 AM
ILOVEGIRLS
Jul 10, 2001 10:34 PM
