Dying turbo?
Old Jul 22, 2001 | 02:20 PM
DC2's Avatar
DC2
Default Dying turbo?
Yesterday I had to take my turbo off because I had to fix a leak coming from the oil return line. I noticed when I took it out the compressor side was moving around as if I was clocking it. I found one of the bolts was missing on the turbine side to tighten it, so I replaced it. Unfortunately, there was still some movement on the compressor side. That's my first problem. So, I checked both compressor/turbine wheels. I wiggled and found there was some play. Correct me if i'm wrong, but isn't the shaft not supposed to move up and down 'at all'? Then, I'm driving around today and I crank up the boost til 10 psi. (I have a DRAG 3 kit) It seems that it didn't hit 10 psi til around 6.5k. Are these all signs of a turbo going south?
Thanks in advance
Old Jul 22, 2001 | 03:16 PM
92CivicSiR's Avatar
New User
Default Re: Dying turbo? (DC2)
yes, it sure as hell is. If it takes that long to hit 10psi of boost, then there aparently is a lot of play in your turbo. depending on the size of your turbo, you should be hitting at least 10psi by somewhere around 3500-4000 RPM
Old Jul 23, 2001 | 09:28 AM
DC2's Avatar
DC2
Does anyone know the average price for a rebuild?
Old Jul 23, 2001 | 09:31 AM
b18bturbo's Avatar
most good turbo shops charge 150-300 bucks to do a turbo rebuild. I usually use majectic turbo cost 150 all the time.
Old Jul 23, 2001 | 09:40 AM
DC2's Avatar
DC2
Default Re: Dying turbo? (b18bturbo)
Okay, thanks.
turbo*s2k
Oct 2, 2014 07:02 PM
95whitegizzer
Jun 28, 2006 05:21 PM
crazzeboost
Jul 20, 2005 07:09 AM
b00stedbyFastrax
May 11, 2004 02:55 PM
B18EG6
Oct 10, 2002 05:48 PM
