Dump tube..
Old Jan 12, 2006 | 04:52 AM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default Dump tube..
I have the trial 38mm waste gate, and when I start my car there is a very little amount of exhaust leaking from the dump tube. Normal?
Old Jan 12, 2006 | 05:03 AM
Mr. Vapor's Avatar
Default Re: Dump tube.. (littleblue)
not normal. this needs to be 100% Shut or else you'll be leaking boost. it should only be open when your boost controller tells it to open.
Old Jan 12, 2006 | 05:06 AM
littleblue's Avatar
Default Re: Dump tube.. (Mr. Vapor)
The thing is I dont have a boost controller, I wasn't planing one investing in one either. I have a pretty good idea of why it is leaking, after looking at all the fittings it comes with..
Old Jan 12, 2006 | 05:18 AM
boostedcivicsir's Avatar
Mr. Badwrench
did you put the wastegate seat in? it is a ring that looks like a flange. that goes into the valve pocket before you bolt it on. if you dont install that it will leak.
Old Jan 12, 2006 | 05:31 AM
littleblue's Avatar
Default Re: Dump tube.. (boostedcivicsir)
That is exactly what I forgot.
Old Jan 12, 2006 | 05:47 AM
Mr. Badwrench
glad it was something easy.
speedfoxracing
Mar 5, 2010 02:33 PM
Mad Cow
Feb 24, 2005 06:12 AM
cjmech
Aug 14, 2002 10:49 PM
Etylorcen
Jun 4, 2002 11:50 AM
