dual stage boost controller and correct tuning????
Old Jun 24, 2003 | 08:31 PM
__37__'s Avatar
Default dual stage boost controller and correct tuning????
im not meaning to jack the thread here, but i have wondered about dual stage boost controllers and tuning. and since poeple were talking about it i thought it would be a good time to ask.
when you get the car tuned, do you get it done for both of the levels you plan to boost at? say i plan to drive 8psi daily and bumb up to 15 at the track. does a fuel management system (ex. hondata) select from from two different fuel maps depending on boost or the switch of a button?
if not, then how do you accomadate for going from 8psi and 15psi and vice versa while avoiding destroying your engine?
Old Jun 24, 2003 | 08:32 PM
Mr. Softee's Avatar
Default Re: dual stage boost controller and correct tuning???? (__37__)
yes it does
Old Jun 24, 2003 | 08:35 PM
__37__'s Avatar
Default Re: dual stage boost controller and correct tuning???? (94goldjungsr)
yes it does as in yes hondata can handle this? is it with the push of a button, or does it change the fuel curve based on boost? what hondata has this feature? is it just the s200 w/ boost or is there something else i would need?
Old Jun 24, 2003 | 10:17 PM
Mr. Softee's Avatar
the x axis is how much boost you are running (map sensor value), the y axis is how many rpm you are at.
you program the fuel at these joining points in the spreadsheet for all boost values.
when you go to that rpm / boost level, the ecu finds the encoded value and uses it.
all hondata have this feature, its how it works, not a feature.
BlackThorN
Dec 21, 2003 12:51 AM
SMOOTH97LUDE
Sep 13, 2003 03:02 PM
boosted_zc
Feb 22, 2003 09:41 AM
tygsr
Jun 19, 2002 01:27 PM
