Doest anybody know if hondata's or aem's can be used to adjust boost
i was thinking about switching from vafc to a hondata or aem standalones. wanted to know if any versions can be used to adjust boost. right now i am not running a boost controller. since they are so expensive i was just going to buy a standalone instead.
Re: Doest anybody know if hondata's or aem's can be used to adjust boost (SMOOTH97LUDE)
with hondata you still need a boost controller. I am assuming you have a tial or similar that cannot be adjusted whereas a deltasuck can. Manual boost controllers are not expensive at all. If you plan on running race gas you can get a dual stage boost controller and switch it over at the track without any trouble. Single stage little over $100 at most places.
Both the AEM and Hondata can adjust boost. The AEM uses a gear/speed dependant boost controller. The Hondata has to be wired up with a dual stage manual boost controller.
lovey408
10-14-2007 08:49 PM
