dsm injectors
Old Nov 16, 2005 | 06:18 PM
marcussmith26's Avatar
Default dsm injectors
Is the black top 450cc dsm injector the same as the blue top.And what size is conquest injectors and will they fit a b18c1
please help!!!!!!!!!!!!!
Old Nov 21, 2005 | 07:33 PM
RallySol's Avatar
Default Re: dsm injectors (marcussmith26)
If you pull them out of an 87 Starquest or newer, black top injectors should be 650cc-ish and the green tops can be anywhere between 1000cc and 1200cc. I'm looking at one right now and it -might- fit. I don't have a b18 to test fit with so I can't say for sure.
Old Nov 21, 2005 | 08:01 PM
RallySol's Avatar
Default Re: dsm injectors (RallySol)
Stock LS injector on the left, 450 DSM in the middle and a 1k Starquest on the right.
*edit* Thanks HiProfile
Modified by RallySol at 11:08 PM 11/21/2005
Old Nov 21, 2005 | 08:44 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RallySol &raquo;</TD></TR><TR><TD CLASS="quote">Stock LS injector on the right, 450 DSM in the middle and a 1k Starquest on the right.</TD></TR></TABLE>
So what's on the left? Starion on the right, DSM middle, LS left. Looks like the starion will be too short, unless you change the height of the fuel rail.
Here's some info on the starion injector (go to the bottom): http://www.witchhunter.com/var...s.htm
The DSM blacktops are exactly the same. The ones I have match up exactly to that picture of bluetops.
Old Nov 21, 2005 | 10:48 PM
bigdaddyvtec's Avatar
* B A N N E D *
ya man ive got the black tops in my setup...physically (size wise) they are identical to the blue tops, there is a difference though the blacktops have a dual spray pattern for better fuel atomization. I like mine, if you are sure you wont outgrow them to soon, id say go for it. should be good to 300 hp or so ( at least that was what i was told for my turbo f22b1) i also got a good deal on them. 70.00 with clips.
Good luck,
Spike
092eg6
Dec 23, 2009 01:38 PM
biada2.2
Jan 28, 2006 02:32 PM
TURBO DC2
May 6, 2005 06:36 AM
alfee
Mar 9, 2004 09:18 AM
turb
Apr 2, 2003 02:17 PM
