DSM injector question??
Old Feb 3, 2005 | 04:51 AM
hybridej7's Avatar
Default DSM injector question??
if i happend upon a dsm in my local yard with the motor actually still in it, along with the clips, what else would i need to get along with the injectors and clips? any certain year to be on the lookout for ? thanks
Old Feb 3, 2005 | 04:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
Look for blue top injectors. They will say 450 on the side of the blue plastic part [very small].
Old Feb 3, 2005 | 05:48 AM
tgreaves's Avatar
Default Re: DSM injector question?? (hybridej7)
Look for a boosted 5-speed dsm.. I know they have the 450's in them but I dont know about any others..
Look at the bottom of the page below..
http://www.homemadeturbo.com/t....html
Old Feb 3, 2005 | 06:24 AM
Cray91's Avatar
you can just use your stock clips if you have a 5th gen. civic.
Otherwise either of the DSM injectros will work. the AT ones have 390's.
Old Feb 3, 2005 | 06:29 AM
hybridej7's Avatar
Default Re: DSM injector question?? (tgreaves)
sweet write up...ill def hold onto this for future reference.... i will be doing this on a 97 civic with a 97 b20 swap, im sure it will work ok. do you need to put those resistors on or can you use a resistor box?
Old Feb 3, 2005 | 06:30 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 &raquo;</TD></TR><TR><TD CLASS="quote">sweet write up...ill def hold onto this for future reference.... i will be doing this on a 97 civic with a 97 b20 swap, im sure it will work ok. do you need to put those resistors on or can you use a resistor box?</TD></TR></TABLE>
You can run either inline resistors or just run a resistor pack, IMO wiring up the box is so much easier..
tgreaves's Avatar
Use a resistor box, its much eaiser than soldering in those inline resistors..
Old Feb 3, 2005 | 06:36 AM
93turbo16's Avatar
it is much easier. I also have a how to on my site. http://www.geocities.com/uncgolf25
showing how to wire in the resistor box. I know I suck at paint.
Old Feb 3, 2005 | 07:21 AM
hybridej7's Avatar
Default Re: (93turbo16)
good write up. i can get one of those resistor boxes like from a crx or w/e right? i had a rex with a b16 in it, it was in it when i bought it so i didnt know anything about the car. i know it scooted like the wind though.....
Old Feb 3, 2005 | 07:32 AM
EJ1 wilcox's Avatar
Default Re: (hybridej7)
I think it's easier to wire up inline resistors than a resistor box...
And it's cheaper, I bought my resistors for like $4 total or something. It's hard to find a resistor box for under $20 or so...
The only thing is... with the inline resistors the car has a hard time starting sometimes... I think the 10w 10ohm resist the current too much... at least that's what I read. Just something to think about. It doesn't bother me much but just something to consider.
Old Feb 3, 2005 | 07:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
As if you wanted another writeup on resistor box install , I've done one and it's on the Knowledge base...just search for 'resistor box'
Old Feb 3, 2005 | 07:42 AM
splitime's Avatar
Default Re: (DaX)
Heh, if you find a 5sp dsm in the yard. Take the injectors, clips, sidemount IC and the turbo. You'll find buyers for that other stuff... and it'll cover the cost of the injectors.
Old Feb 3, 2005 | 08:11 AM
tgreaves's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I think it's easier to wire up inline resistors than a resistor box...
The only thing is... with the inline resistors the car has a hard time starting sometimes... I think the 10w 10ohm resist the current too much... at least that's what I read. Just something to think about. It doesn't bother me much but just something to consider.</TD></TR></TABLE>
I got my resistor box from the junkyard for $5.. If its a 92+ civic all the wires to put the resistor box in are already together in a terminated plug..
Old Feb 3, 2005 | 08:24 AM
kulangot's Avatar
Default Re: (tgreaves)
look at my sig...
Old Feb 3, 2005 | 09:58 AM
MtnCRX's Avatar
Default Re: (sirq2u)
congrats on the ls/ vtec comin
j/k - are those the blue tops w/ clips? if so im interested
95dc2teg
Jul 29, 2006 11:01 PM
b18c1wes
Dec 9, 2004 02:44 PM
Charliehondaman
Sep 19, 2004 09:25 PM
