DSM Injector install Question (searched)
Old Oct 21, 2004 | 04:31 PM
hondaguyef's Avatar
Default DSM Injector install Question (searched)
DO NOT give me a link to homemadeturbo.com or tell me to search!!!
My question is, What do you use on the top for the seal? Do you use the Harder plastic piece(the piece w/ two lips on the OE injectors) or not? Do you use the DSM o-ring or the OE o-ring? Thanks
Phil
Old Oct 21, 2004 | 04:49 PM
93turbo16's Avatar
use the oem dsm seal. fits right in.
Old Oct 22, 2004 | 03:18 AM
hondaguyef's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">use the oem dsm seal. fits right in.</TD></TR></TABLE>
Thanks. The injectors I have now (which I was told are dsm 450's but are not) have a very large upper o-ring and won't fit in the fuel rail. The barrel of these injetcors are the same size as the dsm's(the mani seal had to be modified) but, also have a lower o-ring? I'll just buy some DSM's
Phil
Old Oct 22, 2004 | 06:58 AM
m R g S r's Avatar
Default Re: (hondaguyef)
Maybe they are used ans stretched out O rings. . .
Old Oct 22, 2004 | 08:21 AM
hondaguyef's Avatar
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Maybe they are used ans stretched out O rings. . . </TD></TR></TABLE>
The o-rings are a much larger dia. than usual(oe ones). The tops are grey and they have plymouth emblems on the side of them.?
Old Oct 22, 2004 | 08:27 AM
underpressure02's Avatar
I have never used the dsm injectors but I know for my injectors. I just went to auto zone took my injectors and the fuel rail and played with the different size o-rings till I found one that fit good and tight.
I know once gas hits them they swell up. When I took the fuel rail off to change something I had to get all new orings.
Not sure if that helps.
martial
Feb 21, 2010 08:34 AM
hxtasy
Oct 15, 2006 11:24 PM
honda06si
Mar 12, 2005 03:44 PM
Scean
Nov 9, 2004 09:42 AM
seekerONE
Jun 14, 2002 03:00 PM
