dsm Bov questions
Old Oct 19, 2005 | 06:18 AM
teefunk01's Avatar
Default dsm Bov questions
will a dsm bov work for a 400+ hp turbo setup on a b18c1? Just got one for a good price but not sure itll handle the amount of boost.
Old Oct 19, 2005 | 08:48 AM
Zakar's Avatar
there so cheap u could use 2 of them
Old Oct 19, 2005 | 11:01 AM
teefunk01's Avatar
Default Re: (Zakar)
so a dsm will work or no?
Old Oct 19, 2005 | 11:14 AM
fmfkid250's Avatar
Default Re: (tphan4)
is it the 1st gen or second gen?
it can handle like 15-16 psi i beleive
Old Oct 19, 2005 | 11:22 AM
Tomek's Avatar
Default Re: (fmfkid250)
I've personally seen them hold 20psi on a big 16g....you can always crush it to hold a little more boost.
The dsm bov owns for the money
And its not "I'm an attention *****" loud when you vent into the atmosphere either, yet sounds great.
Old Oct 19, 2005 | 11:35 AM
teefunk01's Avatar
Default Re: (Tomek)
so say I run two dsm bov's.....I mean im going to run small amount of boost at first trying to take it easy after break in....but will two bov still function properly with low amount of boost pressure
Old Oct 19, 2005 | 11:36 AM
Blackack26's Avatar
Default Re: (Tomek)
I've heard rumers of crushed 1'st gens holding 22+ psi no problem, I run one uncrushed on my setup. I love everything about it.
Old Oct 19, 2005 | 11:46 AM
Tomek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tphan4 &raquo;</TD></TR><TR><TD CLASS="quote">so say I run two dsm bov's.....I mean im going to run small amount of boost at first trying to take it easy after break in....but will two bov still function properly with low amount of boost pressure</TD></TR></TABLE>
I don't understand why you want to run 2. (well I think I might have a hunch but I'm biting my tongue for now)
Its not like you need to run 7866lbs of boost to meet your power goals.
Old Oct 19, 2005 | 12:19 PM
teefunk01's Avatar
Default Re: (Tomek)
well seeing as how ive spent over 2 grand on the motor alone not including the turbo yet....I figure maybe one bov (since stock) wouldnt handle the amount of boost I wanted...and the last thing I need is boost pressure not being release properly and damaging something..... and what are you biting your toungue about im not sure what your talking about?
Old Oct 19, 2005 | 12:23 PM
HiProfile's Avatar
In for a penny, in for a pound - I'd suggest getting better hardware if you're so spendy on other parts of the build. Not that the DSM won't work, there are just better options for not much more than 2 DSM's.
Old Oct 19, 2005 | 12:35 PM
teefunk01's Avatar
Default Re: (HiProfile)
well the thing is I already have a dsm bov that I bought.....should I just sell it?
Old Oct 19, 2005 | 12:37 PM
Tomek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tphan4 &raquo;</TD></TR><TR><TD CLASS="quote">well seeing as how ive spent over 2 grand on the motor alone not including the turbo yet....I figure maybe one bov (since stock) wouldnt handle the amount of boost I wanted...and the last thing I need is boost pressure not being release properly and damaging something..... and what are you biting your toungue about im not sure what your talking about?</TD></TR></TABLE>
I was just thinking you wanted it for the "Im a stunna and I have 2 bov's" reason ... don't take any offense to it because it looks like that is not the case for you and I tend to make stupid comments at times heh.
What size turbo and boost level do you plan to run at?
There are plenty of aftermarket bov's that can likely hold the boost that you want to run, plus 400whp can be achieved boosting less than 20psi (depending on the turbo of course) Figure you spent $2k on the motor build why skimp out on what you built the motor for?
Only reasoning I see behind running 2 is possibly less spool time between shifts since it'll vent the air faster :shrugs:
Old Oct 19, 2005 | 12:41 PM
teefunk01's Avatar
Default Re: (Tomek)
Ill be using either a t3/60-1 or a t/t67.....looking at around 20 lbs.....built/stock sleeves
Im just looking at the best bang for the buck now but still be reliable
Old Oct 19, 2005 | 01:06 PM
Tomek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tphan4 &raquo;</TD></TR><TR><TD CLASS="quote">Ill be using either a t3/60-1 or a t/t67.....looking at around 20 lbs.....built/stock sleeves
The dsm can work, as I said I've seen them hold 20psi with my own eyes, but if you want to be on the safe side you can find turboxs bov's for pretty cheap, especially used. Either the turboxs type h, type h34, or rfl. I've seen them go for around 150-175 brand new.
Here's an rfl I just found for $80 https://honda-tech.com/zerothread?id=1399885. RFL is rated to hold up to 25lbs.
Here it is brand new for $169 http://store.summitracing.com/...w=sku
Old Oct 19, 2005 | 01:10 PM
teefunk01's Avatar
Default Re: (Tomek)
thanks for the info man...
Old Oct 19, 2005 | 01:14 PM
Tomek's Avatar
anytime
Old Oct 20, 2005 | 07:21 AM
fmfkid250's Avatar
u do realize 20 psi on a 60-1 is like 500 whp?
Old Oct 20, 2005 | 08:18 AM
teefunk01's Avatar
yes that why I said 400+? I just wanted to say 400 to be on the safe side and not dream about numbers...honestly I just want as much power as I can with a good tune
deeweezy187
Aug 20, 2007 08:53 PM
PnoyJeff
Jan 8, 2007 05:40 PM
redDAinteg
Mar 11, 2006 11:50 PM
mrjdmcivic
Jun 16, 2004 11:36 PM
Smooth-GSR
Apr 3, 2004 05:53 AM
