DSM 450's...
Old Jul 4, 2005 | 08:04 AM
joshcivic00's Avatar
Default DSM 450's...
Do the DSM 450cc injectors fit directly into the engine of a d16y8(with the exception of havind to do resisitors for the wires0is it basically a direct bolt in???
Old Jul 4, 2005 | 08:25 AM
YiNYaNg's Avatar
Default Re: DSM 450's... (joshcivic00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshcivic00 &raquo;</TD></TR><TR><TD CLASS="quote">Do the DSM 450cc injectors fit directly into the engine of a d16y8(with the exception of havind to do resisitors for the wires0is it basically a direct bolt in???</TD></TR></TABLE>
YES, You're correct!
Old Jul 4, 2005 | 08:51 AM
J337_UNIT's Avatar
Default Re: DSM 450's... (H-T)
well only other thing you will have to do is modify the clips that connect to the injector...and widen up the O ring seals.
Old Jul 4, 2005 | 03:10 PM
hotimportcrx's Avatar
Default Re: DSM 450's... (J337_UNIT)
the obd 0 clips will fit right on....you dont even need the injector clips and you dont have to wire the resister box because it already has the box...all you need to do is go to home depot but a dremel comes in a kit....for 30$....and widen up the o rings...its easy...then return the dremel the next day...thats what i did
Old Jul 4, 2005 | 04:53 PM
ryan89crx's Avatar
you dont even have to widen the O-rings. there are methods that avoid that. oil the seals well, gently push injector on enough to get the threads started on the fuel rail. then tighten the nuts on the fuel rail gradually and evenly and the injectors will slide in.
Old Jul 4, 2005 | 06:58 PM
Default Re: (ryan89crx)
i dont know...i put oil on it and it wouldnt go in for nothing.....then i just pushed it really hard in and it leaked all over....so i just did it the right way with a dremel....theres no reason not it its easy as hell
Old Jul 4, 2005 | 07:06 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">you dont even have to widen the O-rings. there are methods that avoid that. oil the seals well, gently push injector on enough to get the threads started on the fuel rail. then tighten the nuts on the fuel rail gradually and evenly and the injectors will slide in.</TD></TR></TABLE>
i've heard this method causes vacuum leaks at the seals.
Old Jul 4, 2005 | 07:17 PM
Johnyquest's Avatar
Default Re: (SOHC_MShue)
Nah, I've done it on 4 or 5 cars w/o widening the O-Rings... A little vaseline and your gold.
Matt
Old Jul 6, 2005 | 05:07 AM
YiNYaNg's Avatar
Default Re: (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">Nah, I've done it on 4 or 5 cars w/o widening the O-Rings... A little vaseline and your gold.
Matt</TD></TR></TABLE>
I did the exact same thing too.
Old Jul 6, 2005 | 05:42 AM
USDM 4G VTEC's Avatar
and i have done it as well in about 6 cars
and guess what
i have seen many people do it ur way , and they end up stripping the damn bolts for the fuel rail , because the injectors wouldnt do in
do it right the right way, and dont force them in
get them sand down to the right size and install them right
and yes even after the dremel u need some oil
Old Jul 6, 2005 | 06:14 AM
Johnyquest's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">and i have done it as well in about 6 cars
and guess what
and yes even after the dremel u need some oil </TD></TR></TABLE>
If you manage to strip the damn bolts on the fuel rail, it's probably YOUR fault. Those studs are quite large considering the minute amount of stress they are actually under. If you start them by hand, and use the middle one to seat the injectors, tighten them only as far as the new injectors will go down ... there will NOT be a problem. If there is, you screwed up. Simple as that. Bolts don't strip themselves.
Matt
Old Jul 6, 2005 | 06:57 AM
mike1114's Avatar
Forget the dremel, my little 120lb *** pushed the injectors in enough to get the fuel rail started then just tighten it all down!! I've done this on two motors, over two years, no problems.
turbotime
May 14, 2006 02:33 PM
marcussmith26
Nov 21, 2005 10:48 PM
honda06si
Mar 12, 2005 03:44 PM
Smooth-GSR
Mar 26, 2004 10:16 PM
alfee
Mar 9, 2004 09:18 AM
