dry, wet, or direct port?
IMO I would go with a Zex dry for your setup. Have your injectors check and make sure the fuel system is in good shape.
I like the idea on small shots for the injectors to supply the fuel (better fuel distribution)
On a direct port wet you have to lower your fuel pressure to run a 50shot and that won't work because you start leaning the injectors out.
Hey spooncivic I cant pm yet but here is your ans
yes that is the whole kit smallest is a 75 shot we ran it on one for 8 mnths no problems before we sold the motor
its a honda thing only for the 18c1 and h22 it uses a unique fogging plate to improve nitrous and fuel atomization along with better mixture disribution
kit comes with bottle plate solenoids fittings and braided lines wiring jets in other words everything for a professional install just make sure you run at least -2 to 4 timing and a two step colder plug
i ran ngks (bkr7e)
i ran ngks (bkr7e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RA166E »</TD></TR><TR><TD CLASS="quote">On a direct port wet you have to lower your fuel pressure to run a 50shot and that won't work because you start leaning the injectors out.</TD></TR></TABLE>
Why is this? Don't they make small enough fuel nozzles?
91integraLSVTEC
Sep 29, 2007 12:42 PM
