dropping boost. possible leak?
Old May 27, 2006 | 03:01 PM
kaj's Avatar
kaj
Default dropping boost. possible leak?
with one boost controller (homemade. brass valve) i get full boost.. then, when vtec kicks in (coincidence, i'm sure), it drops from my 13psi to 8psi (spring)
with another boost controller (air pressure regulator) it reaches 13psi, but not 'till 8k rpm.
my entire setup is put together with T-Clamps.. so i can't imagine it leaking... any ideas?? we're looking to pressurize the system with a pvc cap/leakdown tester to look for leaks..
has anyone had this problem and able to confirm my suspicions?
Mugencrxsir1
Feb 22, 2006 10:02 AM
Sketch_hs
Aug 10, 2004 09:06 PM
bey
Feb 18, 2004 11:19 AM
mrx
Jan 31, 2004 05:33 AM
echo999
Oct 3, 2002 07:41 PM
