Drag oil return
Old Sep 29, 2002 | 07:41 AM
hybrid901's Avatar
Default Drag oil return
Do all drag kits come with a shitty oil return pipe? I'm doing my first Drag install and all this kit has for the pipe for the oil pan is a 90 degree bent turbo with no fittings. No bulkhead, AN nothing is this normal?
Old Sep 29, 2002 | 01:38 PM
275Performance's Avatar
Default Re: Drag oil return (hybrid901)
From looking around, yeap. Just a POS bent pipe.
Old Sep 29, 2002 | 01:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Drag oil return (TDCPerformance)
yes, its normal. Im actually thinking of changing to a ss hard pipe because its so much more cheaper and I can bend it in any direction.
Old Sep 29, 2002 | 01:46 PM
sunny79's Avatar
Yep, unfortunately, its very basic, so you're better of spending a few pounds, sorry bucks if your in the states and pay a visit to your local hardware store and they'll help you. alternatively, you can just drill a flushed hole straight into your oil pan with a flush finish and give it a good mig weld around it with good leaneshing, it should do the job or be safe get the complete fittings from you DIY store
Old Sep 29, 2002 | 02:42 PM
intekragsr's Avatar
Default Re: Drag oil return (sunny79)
Upgrade to a stainless steel return line setup. B18bturbo sells them on this site.
808b18c1boosted
Sep 28, 2004 12:55 PM
heaven4dr
Jun 27, 2004 12:06 PM
HybridKOOP
Jan 22, 2004 03:56 AM
boredracer408
Nov 16, 2003 04:26 AM
Teg4e
Jun 20, 2002 08:34 PM
