DRAG Manifold??
Old Jun 10, 2002 | 10:45 PM
R-1303's Avatar
Default DRAG Manifold??
Anybody else having problems with their drag manifold on their Integra?? i have a 00 ITR and i can't seem to fit the bolt in the bottom center (above dip stick) into my block..also do you drag 3 manifolds warp?? any suggestions comments plz!
Old Jun 10, 2002 | 10:59 PM
qwkteg125's Avatar
Default Re: DRAG Manifold?? (R-1303)
i had that same problem. what i did was replace that bolt with a stud & nut (same as the 2 outer exhaust mani studs on your head).
Old Jun 10, 2002 | 11:10 PM
turbopimp's Avatar
put the bolt in through the manifold before you put the manifold onto the head... then start threading the bolt before tightening the other manifold bolts/nuts... the mani is cast iron and machined true, so it shouldn't warp...
Old Jun 10, 2002 | 11:13 PM
R-1303's Avatar
Default Re: DRAG Manifold?? (turbopimp)
It wouldn't even fit on the manifold where i could of bolted it in..but thanks a lot for the info!! i'll try that stude and nut trick
Old Jun 10, 2002 | 11:14 PM
Flamenco-T's Avatar
are you sure you didn;t put the exhaust manifold gasket inside out ?
I did that before long time ago, and was struglling tor a few hours, come to realize, I put the exhaust manifold inside out..
dont; ask me why...
Old Jun 11, 2002 | 06:01 AM
turbo Si's Avatar
Default Re: DRAG Manifold?? (Flamenco-NA)
I used a stud and bolt!
hondaeg8
May 12, 2006 08:57 AM
BlueShadow
Jun 18, 2005 07:02 PM
R-1303
Jun 1, 2003 12:53 AM
ceemarun
Jul 9, 2002 05:57 PM
