Drag Kit Worry with B16a2 engine and to much engine compression
Old Dec 13, 2001 | 11:08 PM
BLKCRX's Avatar
Default Drag Kit Worry with B16a2 engine and to much engine compression
Hey all jsut a bit worried about the drag kit and fitting it to a b16a2 del sol vtec. because the drag kit dos't have a new head gasket to lower compression...like f-max what r ya thoughts guys ! ??
regards
James
Old Dec 13, 2001 | 11:19 PM
BlueShadow's Avatar
Default Re: Drag Kit Worry with B16a2 engine and to much engine compression (BLKCRX)
regards
James
well I dont know what the DRAG kit uses to control detonation. but the FMAX comes with either a MSD boost timing master or an r ideal head gasket. you can pick which one you want.
the head gasket will not only lower your compression by 1 point but it will also give you sluggish throttle response and a power loss unless you raise the boost to compensate. but when you do that your back where you started.
with the MSD you have control of the amount of timing advance/retard. I believe the MSD works by detecting knock and if it does it adjusts your timing accordingly.
IMO I would go with the MSD and a good fuel solution to prevent detonation.
Old Dec 13, 2001 | 11:36 PM
BLKCRX's Avatar
Default Re: Drag Kit Worry with B16a2 engine and to much engine compression (BlueShadow)
ok so the MSD would work the same as the J&S Ultra Safeguard V2 Upgrade: $500.00 on the group buy.. humm looks like i might go drag.. after all...even thow i spend the last yr telling eveyone one f-max was the best eheh
Old Dec 14, 2001 | 04:50 AM
BlueShadow's Avatar
I dont know the features of the MSD or the J&S, some systems automatically retard timing IF it detects knock some systems retard timing based on boost pressure (I think). like I said I'm not an expert on those systems, ask around to see what the different features are on different systems.
Old Dec 14, 2001 | 09:00 AM
brian b's Avatar
New User
MSD BTM does not automaticly remove timing.. only the J&S sorta does that.
your best bet is an ecu (hondata 2b, etc) and a dyno.. all those hours of jumping into your car listening for detonation and trying to figure out if your car is running properly and if you can punch it are gone
Old Dec 14, 2001 | 09:24 AM
DragII's Avatar
25 Year Member
DRAG kit @ stock boost pressures will be just fine on your B16a2 w/ out reducing compression.
Old Dec 14, 2001 | 01:08 PM
01geeser's Avatar
New User
the msd btm only gives you retard depending on psi. for instance 1 degree for ever pound.
2seatteg
Feb 20, 2004 04:48 AM
Saloon-Cruiser
Nov 11, 2003 12:10 PM
sunny79
Oct 20, 2002 02:58 PM
TerdFerguson
Oct 6, 2002 05:59 PM
threatcon13
Sep 6, 2001 02:46 PM
