DRAG Kit problems!
Old Dec 16, 2002 | 02:35 PM
R-1303's Avatar
Default DRAG Kit problems!
Are any of you guys running drag kits having problems with bolts staying tight?? the bolts on my drag kit that connects the manifold to turbo and turbo to down pipe keeps comming loose..what could be the cause?? or a solution? any comments or suggestions are very welcomed.
r-1303
Old Dec 16, 2002 | 02:40 PM
inspyral's Avatar
Default Re: DRAG Kit problems! (R-1303)
Blue Loctite?
Old Dec 16, 2002 | 02:47 PM
Evil EG's Avatar
Default Re: DRAG Kit problems! (inspyral)
Try torquing it down more... I have never had a problem with mine. I wouldnt use lock tight because if you ever wanna take the turbo off the manifold. The heat from the manifold makes the bolts hard to get out, it would be twice as hard with lock tight... Thats my opion anyway.
Old Dec 16, 2002 | 02:51 PM
khang77642's Avatar
Default Re: DRAG Kit problems! (BVM)
Old Dec 16, 2002 | 02:54 PM
Quaalude's Avatar
Default Re: DRAG Kit problems! (khang77642)
Lock washers?
Old Dec 16, 2002 | 02:58 PM
inspyral's Avatar
Blue Loctite is the weaker stuff...
I wouldn't put red Loctite on dp/manifold bolts, but I don't see a problem wih blue Loctite.
Old Dec 16, 2002 | 03:12 PM
swrdply400mrelay's Avatar
Blue Loctite?
Old Dec 16, 2002 | 03:33 PM
CalvitoSol's Avatar
Default Re: DRAG Kit problems! (swrdply400mrelay)
go to autozone and ask for loctite. it should be next to all the silicone gasket makers, adhesives, jb weld, etc. it comes in a tube and should run a few dollars. just put some on the threads and torque em down.
Old Dec 16, 2002 | 04:01 PM
R-1303's Avatar
Blue Loctite?
i though of using loctite..but can it withstand the heat from the manifold???
Old Dec 16, 2002 | 04:26 PM
vtec.dc2's Avatar
http://www.buyitsellitfixit.com/loctite.htm, maybe green 620 - holds up to 450F, but don't know if you'll be able to remove it after that. - maybe not the best option.
not a r
May 28, 2008 04:06 PM
nickromeo
Feb 21, 2005 06:32 PM
DubyaAye
Feb 10, 2004 03:34 PM
Leimokei
Oct 12, 2001 03:39 PM
