drag gen 3 install help question
Old May 10, 2002 | 08:52 AM
tygsr's Avatar
Default drag gen 3 install help question
K we dont have any gaskets for the turbo to the manifold and the turbo to the downpipe, do the kits normally come with these? ANd if not do I need to order some? help asap
Old May 10, 2002 | 08:55 AM
intekragsr's Avatar
Default Re: drag gen 3 install help question (tygsr)
dont need it. I used one though. Drag kits do not come with it
Old May 10, 2002 | 08:57 AM
integRated109's Avatar
my kit didnt come with them, seals fine without them. dont worry about it
Old May 10, 2002 | 09:06 AM
maxim's Avatar
Default Re: drag gen 3 install help question (integRated109)
No, they do not come with kits but I made my own gaskets and they look really good. The best way to make them if you need to is to:
1)get some gasket material from any autoparts store(I found some at Autozone)
2)get alum. foil and spray some light adhesive on one side.
3)place the adhesive side of the foil on the turbine inlet and outlet holes(for dp and manifold)
4) carefully trace your finger over the edges and the holes where you have an outline of all the little holes and edges.
5)now carefully take the foil off and place the adhesive side on the sheet of gasket material.
6) take an artists knife or razor sharp knife and run the blade along the traced edges and holes.
7)all holes and edges should be visible, so use a Dremel and carefully cut off edges and holes in gasket material.
[Modified by maxim, 12:07 PM 5/10/2002]
Old May 10, 2002 | 10:15 AM
tygsr's Avatar
Default Re: drag gen 3 install help question (maxim)
thanks for the info, anyone had any problems not using any sort of gasket?
Old May 10, 2002 | 10:40 AM
Etylorcen's Avatar
If you drive around and notice it pausing or hear it leaking then you might want to get a gasket. Most likely you wont need it.
Old May 13, 2002 | 07:58 PM
turbopimp's Avatar
don't need them...
intekragsr
Feb 2, 2003 04:02 PM
R-1303
May 19, 2002 03:09 PM
reefer_bob
Jan 7, 2002 11:03 PM
wwcivic
Sep 3, 2001 05:45 PM
