DRAG FMIC KIT AND REVHARD TURBO?
I was wondering if a Drag FMIC kit will kit on my Revhard turbo kit? I did a search and couldnt find anything..
Re: DRAG FMIC KIT AND REVHARD TURBO? (oemDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 »</TD></TR><TR><TD CLASS="quote">I was wondering if a Drag FMIC kit will kit on my Revhard turbo kit? I did a search and couldnt find anything..</TD></TR></TABLE>
Does anyone know?
Does anyone know?
Isn't anyone on this forum running a revhard turbo kit with drag piping and intercooler? I know theres got to be someone out there. I'm pretty sure it'll fit, but im just making sure.
Re: (oemDC2)
That's enough guys. Back to the topic.
Are you asking if you could use a DRAG IC and DRAG IC piping with the rest of your REV hard kit. If so, yes you can and it will fit. You will of course need to weld a different blowoff valve flange since both kits come with different blowoff valves.
or
are you asking if a DRAG IC will work with your rev hard pipes and the rest of the REV Hard kit? If so, the only problem you will encounter is that the Inlet on the DRAG intercooler is smaller than the diameter of the REV hard piping on the inlet side. You can of course fix this problem easily. If you currently own the Rev hard intercooler, keep it. Don't go for the DRAG IC. The rev hard IC is a better size and will work with higher HP applications. Good luck.
Come on guys, help each other out with questions. We are all on here to learn more so share your knowledge and don't call people retards.
or
Re: (TurboCX)
Thanks for the response TurboCX, thats exactly what i wanted to know. I have a revhard turbo kit, and i am planning on buying a new drag fmic kit becuase i currently have a starion fmic. The spearco fmic that comes with the drag kit will support 400hp i believe and revhard will support 500hp correct?
Re: (oemDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 »</TD></TR><TR><TD CLASS="quote">Thanks for the response TurboCX, thats exactly what i wanted to know. I have a revhard turbo kit, and i am planning on buying a new drag fmic kit becuase i currently have a starion fmic. The spearco fmic that comes with the drag kit will support 400hp i believe and revhard will support 500hp correct?</TD></TR></TABLE>
Those numbers sound just about right. I made a little over 350WHP on the DRAG IC on my old setup and it worked just fine. I ran alot of races and tons of test and tunes and it worked just fine. Good night guys.
