DP starting to rust!
My downpipe is starting to rust and I was wondering if there is something I can do about it. Can I sand the rust off and spray something on it?? Is there anything that wouldnt burn right off? I usually wouldnt care, but it just really sticks out in the engine bay.
a coating would probably be best, but when the guy at the muffler shop was installing my downpipe he welded it straight to the exhaust, so I basically I would have to get the whole exhaust done and I think that would be very expensive.....What kind of high temp paint will hold?? I've tried a few kinds on my mani and none of them stayed on very long.
VHT is the company...you can get it at most speed shops. Their 1500 deg "flame proof" will hold up fine. It works best if you can heat the metal a bit before painting. If not an option, then just make sure you sand and clean the metal with brake cleaner or other strong solvent (not carb cleaner, it leaves a residue)
if you can't find the VHT paint try this website
http://www.caswellplating.com/vht/vht_high.htm
gapsook
Jun 19, 2004 09:35 AM
