Downpipe, why flexpipe?
Old Jul 15, 2003 | 04:16 AM
JJFreshy's Avatar
Default Downpipe, why flexpipe?
Did a search and could not find the specific answer...
Is flexpipe only needed if you do a custom downpipe setup? Or can I use a testpipe with the original greddy downpipe? Why is this?
Going to 3" exhaust and need to know. Setup is a 18G Greddy turbo kit on B18b, 4 door LS. Thanks for any help. Going to order from Kteller most likely or go with Thermal Turbo from K-S..
Jay
Old Jul 15, 2003 | 04:34 AM
PM-Performance's Avatar
Default Re: Downpipe, why flexpipe? (JJFreshy)
the flex pipee alows some movement and flex in the dp so it helps prevent cracking of the manifold.
Old Jul 15, 2003 | 05:29 AM
JJFreshy's Avatar
Default Re: Downpipe, why flexpipe? (itr206)
Ok, well if I am going to 3 inch exhaust do I need to weld flex pipe onto my greddy downpipe and hook the cat back on from there or is a test pipe OK to use with the greddy setup/downpipe? I hope I dont sound like a ... Thanks
Old Jul 15, 2003 | 05:35 AM
you can either use a flex pipe or use spring bolts like they put on the cats from the factory, its user preference though. some use thme , some dont i just used one just for peace of mind.
Old Jul 15, 2003 | 11:44 AM
JJFreshy's Avatar
Anyone else have any other opinions on this? Another post says 3" is too big for a basic Greddy setup. Running stock boost.
Old Jul 15, 2003 | 11:46 AM
like i said i run a 2.5 inch apexi n1 i had with my na set up . i amde my pwoer on my 1st tuning session i coulda got more on the next one . mie didnt hold me back much , it staying on too , i will just open the dp via cutout when i need the rest of the umph.
its a **** load cheper then getting a new ex system
Old Jul 15, 2003 | 12:08 PM
Burke's Avatar
Banned
i just made a 3 in downpipe and exhaust for my car. i didnt use a flex pipe, yet. i will once i break a weld, and i am sure i will. you would be suprised how much your motor torques on stock mounts.
i would you use one if i were you
zach1288
Jan 7, 2009 09:49 AM
ksSI
Mar 29, 2006 06:25 PM
DraconicPenguin
Dec 21, 2005 10:50 PM
