Downpipe to turbo connection, use copper spray or no?
It's a 5-bolt downpipe. Would using copper spray give a better seal and be less likely to have any leaks? or is it fine without it?
Re: Downpipe to turbo connection, use copper spray or no? (ALL MOTOR LS)
you really dont need anything as long as your flange is straight and not warped nd your turbo is clean it should have no issues sealing
Re: Downpipe to turbo connection, use copper spray or no? (b18bturbo)
I use a couple coats of coper spray on outlet flanges. Seems to help a bit. When I take them apart you don't see any black areas from soot like you might w/o the spray. Definitely not a necessity especially for new/flat parts.
Acura_I-RS
04-15-2003 12:11 AM
