Downpipe Bolt Which type to use?
Old Nov 1, 2005 | 07:39 PM
Snail EK's Avatar
Default Downpipe Bolt Which type to use?
Which type of bolt are you guys using on your turbo downpipe? I need a allen type SS bolt but I can't find it at any hardware store.
Old Nov 1, 2005 | 08:05 PM
shyboy817's Avatar
use studs.
Old Nov 1, 2005 | 08:06 PM
Snail EK's Avatar
Default Re: (shyboy817)
Where can i get it? is there a difference with heated bolts?
Old Nov 1, 2005 | 08:17 PM
shyboy817's Avatar
message flamenco-t he can get you anything you need for great prices.
Old Nov 2, 2005 | 08:44 AM
Squirtle's Avatar
fast-turbo.com
shyboy817's Avatar
Which is Stan, there site isn't up yet, but they have a # on there to call, or you can PM stan @ flamenco-T
Old Nov 2, 2005 | 08:48 AM
weiRtech's Avatar
OG Fabricator
stainless isn't absolutely nescassary. i'm just using regular grade shcs. if you are having trouble find what you need try http://www.mcmaster-carr.com they have just about everything.
Old Nov 2, 2005 | 08:51 AM
B18C1CYA's Avatar
Default Re: Downpipe Bolt Which type to use? (Snail EK)
We use just normal allen head bolts , or in some cases you can use oem pressure platw bolts they work nice and have a small head.
Old Nov 2, 2005 | 09:02 AM
shyboy817's Avatar
anybody use studs? how long are they? my flange on the dp is at a pretty good angled, doesn't seem like a stud would fit through it.
Old Nov 2, 2005 | 12:14 PM
BoostedCivicSedan's Avatar
I use pressure plate bolts with lock washers... they are small so they fit great....
Old Nov 2, 2005 | 02:36 PM
RyanEJ8's Avatar
I also use stainless allen head bolts. I had to pick them up at specialty bolt store.
Old Nov 2, 2005 | 02:45 PM
ScottEK's Avatar
Default Re: Downpipe Bolt Which type to use? (RyanCivic2000)
We get stainless allen bolts at Ace Hardware, the offical name is "Metric Socket head cap screws".
Old Nov 3, 2005 | 10:22 AM
Snail EK's Avatar
Default Re: Downpipe Bolt Which type to use? (ScottEK)
Thanks for the good information guys. I have the Stud kit but My dp has some tight fitment so it didn't work and if it did only 2 out of 4 would work. I've called stan. He doesn't have any Allen type bolt anymore. Thanks.
Old Nov 3, 2005 | 12:23 PM
mike1114's Avatar
I'll doubt an allen head bolt will work if your downpipe has a tight bend to it, the head of those allen bolts are TALL, they usually won't fit. Then U gotta either get an allen head socket in there or an alley key which won't fit or tighten well either.
What I had to do with my full race downpipe was use studs coming out of the turbo with jam nuts (they are shorter in height than most nuts) to hold on downpipe.
Or option two is bash the hell outta the downpipe with a cold punch and hammer at the bolt holes to dent the downpipe some so the bolts/nuts will fit into their holes.
Old Nov 3, 2005 | 02:15 PM
shyboy817's Avatar
I'm looking to get either studs or bolts for my dp too, what do you guys suggest? I would like to use studs..but I'm not sure if it'll work cause it's a full 3" dp...tight angle..
Old Nov 3, 2005 | 02:19 PM
RyanEJ8's Avatar
Default Re: Downpipe Bolt Which type to use? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">
Or option two is bash the hell outta the downpipe with a cold punch and hammer at the bolt holes to dent the downpipe some so the bolts/nuts will fit into their holes.</TD></TR></TABLE>
Thats what I did and I also cut the bolt a little shorter.
Old Nov 3, 2005 | 02:23 PM
shyboy817's Avatar
Don't know about denting up the downpipe..
dustin
Engine Machining & Assembly
27
Jan 10, 2018 11:41 PM
dandaman15
Suspension & Brakes
Mar 5, 2010 12:25 PM
goose21
Dec 6, 2004 12:05 PM
u2civic1
Apr 14, 2004 06:28 PM
rondigs
Dec 28, 2002 12:38 PM
