Downpipe...2.5 or 3 inch?
Old Aug 3, 2002 | 10:45 PM
IntegD's Avatar
New User
Default Downpipe...2.5 or 3 inch?
Im going to be running 10-11 psi on my gsr(stock internals) and I need a downpipe for my custom setup. I am stuck on how big I should make it. I do want a 3 inch exhaust, but I dont know about downpipe and cat. I assume I will want to go with a 3 inch downpipe, but I heard they spike and thats the last thing I want on stock internals. Will 2.5 do the job?? Or should I go with the 3 inch? Thanks for replies...
Old Aug 3, 2002 | 11:01 PM
rjardy's Avatar
Default Re: Downpipe...2.5 or 3 inch? (IntegD)
If you go with a 3 inch you will not be able to retain your AC. that may answer your question..
Rob
Old Aug 3, 2002 | 11:18 PM
Ri5e's Avatar
Default Re: Downpipe...2.5 or 3 inch? (rjardy)
3 Inch you will spike with a Drag manifold because of the way the wastegate is located.
Old Aug 3, 2002 | 11:46 PM
blkDOHCsol's Avatar
New User
Rob
dis boy aint gonna have a/c..
Old Aug 3, 2002 | 11:52 PM
blufke's Avatar
Default Re: Downpipe...2.5 or 3 inch? (blkDOHCsol)
is it worth it to get a 3" (thermal for instance) exhaust running a 2.5" dp?
Old Aug 4, 2002 | 07:44 AM
TurboSedan's Avatar
New User
Default Re: Downpipe...2.5 or 3 inch? (blufke)
Yes, it most definately is!
Old Aug 4, 2002 | 10:41 AM
IntegD's Avatar
New User
Default Re: Downpipe...2.5 or 3 inch? (TurboSedan)
My CX doesnt have ac anyway, but I will be using an inlinepro manifold with a tial wastegate. Is it still gonna spike?
Old Aug 4, 2002 | 12:04 PM
Speed PHreak's Avatar
Default Re: Downpipe...2.5 or 3 inch? (BG Boost)
I found that the WG flange on Drag manifold was not very well matched with the gasket. A little porting on the flange ought to solve the spiking problem.
hialeahzbg
Mar 2, 2010 11:22 AM
AzntaggeR
Mar 12, 2005 09:49 AM
countryboy
Feb 10, 2005 12:24 PM
n0pinitr0us
Dec 23, 2004 09:43 AM
lazy bum shaughn
Feb 4, 2003 02:34 PM
