doubling up head gaskets
Old Apr 14, 2006 | 10:04 PM
RICE POLICE SIP's Avatar
Default doubling up head gaskets
THe search isn't working right now... But my question is... Has anyone doubled up the OEM HONDA head Gasket to lower compression? Does it work? What were the pros and cons... ETC... The reason for the question is.. My wife has a JDM D15B VTEC and the compression is a little to high for boost and we want to lower it a bit... TIA
Shane
Old Apr 14, 2006 | 10:16 PM
komat's Avatar
Default Re: doubling up head gaskets (Split Image Prez)
if its a stock d15b
its not high in compression you be fine
as for doubling up on headgasket.. dont even think about it
Old Apr 14, 2006 | 10:19 PM
Default Re: doubling up head gaskets (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">if its a stock d15b
I thought the JDM D15b VTEC had high compression... That's how it made 130HP ... Is that wrong?
Old Apr 14, 2006 | 10:20 PM
komat's Avatar
9.6:1 is the compression
Old Apr 14, 2006 | 10:21 PM
WHAT??? Really??? How does it make 130 then? And what's the comp. of the USDM D15B7?
Old Apr 14, 2006 | 10:24 PM
komat's Avatar
9.2
they arnt even the same motor
Old Apr 14, 2006 | 11:00 PM
boosted_93's Avatar
ya you can boost on high compression to you can just run more boost with lower compression
Old Apr 15, 2006 | 06:27 AM
ella94's Avatar
Can run a fairly decient ammount of boost on stock d series. They dont have near high compression as a b16a or b18c. With a diet of 100+ octane gas and some good tuning, your safe up to about 190~ whp
After that, stronger rods and forged pistons are almost a must.
Old Apr 15, 2006 | 10:00 AM
ILLICON5000's Avatar
Default Re: (ella94)
no, not true. people have made 220+ on pump gas....the weak link is the rods
Old Apr 15, 2006 | 11:00 AM
b18sihatch's Avatar
Default Re: (ILLICON5000)
doubling up the gasket i would say may create a problem, why not just get a aftermarket head gasket to lower compression? and with higher compression your hp goals will be easier met with lower boost, and high boost and lower compression
Old Apr 15, 2006 | 11:20 AM
Default Re: (b18sihatch)
I'm thinking about getting a thicker gasket but was just wondering if anyone had doubled up...
Old Apr 15, 2006 | 12:07 PM
Default Re: (Split Image Prez)
gotta remember timing belt a real thick head gasket COULD cause issues with this
Old Apr 15, 2006 | 12:22 PM
rudebwoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLICON5000 &raquo;</TD></TR><TR><TD CLASS="quote">gotta remember timing belt a real thick head gasket COULD cause issues with this</TD></TR></TABLE>
how is that? its not like he is using a 1" thick head gasket, but you will blow the head gaskets easier if you double them up
Modified by rudebwoy at 9:12 PM 4/18/2006
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Split Image Prez &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking about getting a thicker gasket but was just wondering if anyone had doubled up...</TD></TR></TABLE>
Just get a thicker gasket if you feel like you have to. You'll probably be thankful that you did.
Old Apr 16, 2006 | 03:20 PM
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">how is that? its not like he is using an thick head gasket, but you will blow the head gaskets easier if you double them up</TD></TR></TABLE>
imagine using a 1 inch thick headgasket....do you think the timing belt would even string?
same concept but on a smaller scale. the timing belt will still string but there's a small chance that it'll stretch and jump a tooth etc
Techna600f4i
Jun 19, 2006 11:49 PM
i20ar
Sep 17, 2005 12:48 PM
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
ITR_1211
Jan 18, 2004 08:09 AM
All-Motor H22A
Dec 4, 2003 05:54 PM
