Double headgasket...
Old Mar 31, 2003 | 07:27 PM
civictyper85's Avatar
Default Double headgasket...
Has anyone had any experience with using two stock head gaskets to lower comp. and be able to boost more? My friend gave me the idea but im kind of hesitant... I am running really good trap speeds on 9 lbs of boost stock comp...but I think I might be able to squeeze lower ets if i lower the comp and turn up the boost....
Chris
Old Mar 31, 2003 | 07:32 PM
Tinker219's Avatar
Default Re: Double headgasket... (civictyper85)
ive always wondered this myself..anyone?
Old Mar 31, 2003 | 09:28 PM
lazerus's Avatar
Default Re: Double headgasket... (Tinker219)
don't waste your time. if you're going to yank the head off, you might as well get into the block a little bit more!
Old Mar 31, 2003 | 09:30 PM
turbochic's Avatar
chris what kind of setup do you have? engine? turbo? in the process of seting up mine, and would like to see what people say.
Old Mar 31, 2003 | 09:58 PM
b16ahybrid's Avatar
here's an idea why not just buy a thicker head gasket instead of stacking two?
or heres and even better idea, tune it better so you can run more boost ...
I heard this a while back from a few people and the more i think about it the more sense it makes
K.I.S.S. Keep It Simple Stuipid.
enough said
Old Apr 1, 2003 | 01:36 AM
MiraiZ's Avatar
Default Re: Double headgasket... (b16ahybrid)
the headgasket will become your weakpoint...I don't think that stacking them will create a proper fit because they won't mate properly
Old Apr 1, 2003 | 02:42 AM
intekragsr's Avatar
Default Re: Double headgasket... (MiraiZ)
plus thicker headgaskets tend to create a hot spot on the top of tje cylinder which could make you a little more prone to detonation. I say just lower the comp via pistons.
Old Apr 1, 2003 | 06:19 AM
T3T495GSR's Avatar
Default Re: Double headgasket... (intekragsr)
thanks. i was wondering that myself
Old Apr 11, 2003 | 03:29 PM
dank9513's Avatar
Default Re: Double headgasket... (T3T495GSR)
i got a 95 turbo ls, that i used (2) stock headgaskets on. The big problem im having is that it raises the head just enough where your half a tooth off on you cam timing. adjustable cam gears is my next step. i'm running 10lbs with everything stock except 450cc injectors and i have no detenation what so ever. IF i can figure out this timing issue it will be a AAA+++
Old Apr 11, 2003 | 04:53 PM
Agtronic's Avatar
Default Re: Double headgasket... (dank9513)
Us VW guys use this trick on the 4 cyls with zero probs. I know VWs and Hondas aren't the same at all. I don't think I'd want to use this method on a Honda. VWs have a poor cylinder head design (excluding the 20v) so running two gaskets doesn't affect anything. But in a precise engine like a VTEC, you'll probably be better off using a lower compression piston.
My 0.02 ...
Old Apr 11, 2003 | 06:35 PM
MiraiZ's Avatar
Default Re: Double headgasket... (Agtronic)
thicker gaskets may be okay...although mine blew bigtime...but stacked headgaskets??...
Old Apr 11, 2003 | 06:57 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dank9513 &raquo;</TD></TR><TR><TD CLASS="quote">i got a 95 turbo ls, that i used (2) stock headgaskets on. The big problem im having is that it raises the head just enough where your half a tooth off on you cam timing. adjustable cam gears is my next step. i'm running 10lbs with everything stock except 450cc injectors and i have no detenation what so ever. IF i can figure out this timing issue it will be a AAA+++ </TD></TR></TABLE>
you should be fine up to about 12psi with a stock b18b with 1 stock head gasket.
924doorEG
Mar 9, 2008 11:01 PM
D-meet07
Nov 4, 2004 06:29 PM
mozez
Jan 13, 2004 08:48 PM
teamrocket si
Jul 6, 2002 12:52 AM
Charles B.
Oct 29, 2001 09:26 AM
