Does this turbo setup need BTM?? help!
Old Jul 14, 2003 | 09:16 PM
Fired Honda's Avatar
Default Does this turbo setup need BTM?? help!
Drag turbo with BOV pipe and everything
t3/to4B
7psi turbonetic Wastegate
high press pump
370cc injector
Apexi VAFC
I'm currently running 3psi only, but i'm going to tune the car next week. Just wondering Do I need a MSD 6A ignition thing?...because i'm planning running 7-8psi and dont know if I need any ignition timing in those kind of boost level....
Or I can just change distributor direction so spark come in advance...Other than go out and spend hundreds of dollars on the 6A ignition...
Please help...Apreciated
Old Jul 14, 2003 | 09:55 PM
u2civic1's Avatar
Default Re: Does this turbo setup need BTM?? help! (Fired Honda)
i have a msd 6a with coil blaster 2and gsr cap for sale
all for 100 bucks
Old Jul 14, 2003 | 10:00 PM
hmm ...I buy it from you...
Does it fit on 6th accord? Does it come with wire's and everything?..Do you have any instruction how to install it? and 100 bucks on everything? I'm looking to have it right away, 1 day shipping ...Do you have paypal?
Old Jul 15, 2003 | 10:12 AM
Pengo's Avatar
Default Re: (Fired Honda)
i thought u were askin about the btm. are you lookin for a more powerful spark or to retard timing to safely run more boost?
Old Jul 15, 2003 | 10:47 AM
I dont really sure about more spark or retard timing.. What should be my best task runnning 8psi of boost on Drage genII kit..??? Running a VAFC hack and 370cc injector...
Thanks for the reply
Old Jul 15, 2003 | 10:49 AM
JimmyT89's Avatar
just curious, how are you running 3psi of boost when ur wastegate is set at 7psi. also, get rid of hte deltagate and get a tial, deltagate will spike like crazy and Fu*k your motor up. i learned
Old Jul 15, 2003 | 01:09 PM
ion_four's Avatar
I'm also wondering how you are running 3psi, sounds like a fubar'd wastegate or a boost leak. The 6A will do nothing to change your ignition timing. The BTM or 6BTM will retard timing with boost. It would be most wise to get the 6btm (or a rom for your ecu) to retard timing. ALSO, you will most likely get a CEL (check engine light) if you are getting sufficient fuel with the 370's and the VAFC because it will not be trimming out enough of the MAP voltage. If you don't understand this, search.
Old Jul 15, 2003 | 07:28 PM
scttydb411's Avatar
i would recommend a btm and larger injectors. your boost will be limited to 6-8psi max because you will not be able to correct the map as much with those injectors. also a btm will be a good way to run a better timing at lower or out of boost and also give you the ability to reduce timing if you get bad gas, etc.
Steeve_Civic
Engine Management and Tuning
Nov 22, 2011 08:20 AM
93hatchboosted
Jul 10, 2004 01:51 PM
4inspeed
Feb 9, 2004 01:13 AM
CalvitoSol
Jul 3, 2002 03:25 AM
smoothludey2
Jan 7, 2002 08:00 PM
