Does something sound wrong with my engine? (Video)
Old Jul 15, 2006 | 09:56 AM
  #51
rudebwoy's Avatar
sounds like rod knock from bad bearings, but it usually gets louder when you rev, but it did not.
Old Jul 15, 2006 | 10:00 AM
  #52
abmerop18's Avatar
Default Re: (rudebwoy)
i take back what i said before about the clutch. when i press the clutch down, the sound completely goes away. i think this means that it is the input shaft bearing, am i correct?
Old Jul 15, 2006 | 12:33 PM
  #53
komat's Avatar
Default Re: (abmerop18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">i take back what i said before about the clutch. when i press the clutch down, the sound completely goes away. i think this means that it is the input shaft bearing, am i correct?</TD></TR></TABLE>
most likely
or the throwout bearing
is it getting harder to shift?
Old Jul 16, 2006 | 12:02 AM
  #54
SOHC_MShue's Avatar
yup sounds like input shaft bearing. I had the same problem. When we took the tranny apart the ***** all fell out of the bearing
Old Jul 16, 2006 | 03:25 AM
  #55
Enzo Speed's Avatar
Default Re: (SOHC_MShue)
Sounds like my car. I replaced the pilot bearing and it didn't help. I didn't want to fart around with the tranny, so I deal with it.
How hard is it to replace said "input shaft" bearing?
Old Jul 16, 2006 | 07:09 AM
  #56
abmerop18's Avatar
Default Re: (Enzo Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like my car. I replaced the pilot bearing and it didn't help. I didn't want to fart around with the tranny, so I deal with it.
How hard is it to replace said "input shaft" bearing?</TD></TR></TABLE>
pretty hard you have to take out the tranny, unbolt the clutch housing from it, remove the gears and then replace the input shaft bearing. all this for a $30 part. im most likely going to buy a new transmission to save myself the hassle since i can get one for only like $200-300.
Old Jul 16, 2006 | 09:09 AM
  #57
h22 civic's Avatar
check the flywheel bolts
Old Jul 16, 2006 | 09:13 AM
  #58
GarageAlchemist
Guest
Posts: n/a
Default Re: (h22 civic)
i don't know, but i'd pull the engine and get it solved.
Old Jul 16, 2006 | 09:30 AM
  #59
SOHC_MShue's Avatar
Default Re: (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">i don't know, but i'd pull the engine and get it solved.</TD></TR></TABLE>
pull the engine? Didn't you see he just figured out its the tranny?
As for pulling the tranny apart it really isn't all that hard. My friend helped me pull mine apart when mine broke and the only hard thing was getting the gears all lined up back in there, but it only took probably 20-30 minutes to replace the bearing after the tranny was out.
Old Jul 16, 2006 | 10:23 AM
  #60
Tad's Avatar
Tad
buh buhbuh buuuh(trumpets)
https://honda-tech.com/zerothread?id=596873
Old Jul 16, 2006 | 10:31 AM
  #61
abmerop18's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">buh buhbuh buuuh(trumpets)
https://honda-tech.com/zerothread?id=596873</TD></TR></TABLE>
thanks man
wgbm92
May 7, 2012 11:40 PM
Rok_Stok
15
Mar 21, 2010 12:50 PM
zeplin
16
Dec 31, 2008 07:22 AM
atarigamer01
Jan 11, 2008 07:52 AM
Hoodwinked
Sep 26, 2003 01:11 PM
