Does rebuilding a turbo end shaft play?
Mr. Badwrench
Re: Does rebuilding a turbo end shaft play?
in and out is bad. that means the thrust bearing is gone.
you will always have a little side to side ont a journal bearing turbo. until it has oil pressure to suspend the shaft.
right, in and out is bad. but i belive the thrust bearing is in this kit correct?
http://cgi.ebay.com/ebaymotors/TURBO...Q5fAccessories
so it would end shaft play side to side and in and out, correct?
thanks again for the help, just want to cover the bases before i pick up this turbo.
the guys at g pop shop are great, i have had a turbo rebuilt buy them one of the worst i had seen it had massive shaft play and it came back and looked brand new.
worked great
worked great
