Does this look right? pics
Old Jun 29, 2004 | 07:08 PM
sneakypete's Avatar
Default Does this look right? pics
In the instructions it says to have the arrow point towards the wastegate. I have the boost controller turned all the way down on both dials (dual stage). It should only go to 7 psi (wastegate spring). However it jumps to 10 psi. The power wire from the boost controller is connected to the switch, and another wire from the switch to a 12v power source. What has me puzzled is, if its hooked up wrong why is it boosting past the wastegate spring? I had a greddy tvvc manual boost controller hooked up before this and it worked perfect. Just got tired of popping the hood all the time to adjust the boost.
Old Jun 29, 2004 | 07:32 PM
honda9369's Avatar
god damn that rad. is huge. where did you get it?
Old Jun 29, 2004 | 07:34 PM
sneakypete's Avatar
Default Re: (honda9369)
Its not that big, its a PWR half size dual core radiator. The angle of the pics make it look bigger then it actually is.
Old Jun 29, 2004 | 07:39 PM
Suprdave's Avatar
Same thing happened when i installed one...you need to get a smaller WG spring I believe.
Old Jun 29, 2004 | 08:02 PM
Muckman's Avatar
Moderator in Chief
Default Re: Does this look right? pics (sneakypete)
Damn I just wouldn't trust that rubber hose that close to the super hot wastegate. From the picture it looks like its practically laying on the flange.
Get a muckman kit https://honda-tech.com/zerothread?id=825972
Old Jun 29, 2004 | 08:07 PM
braintree's Avatar
The size of the spring limits how LOW you can go. If it's a 7lbs spring, you can boost higher than that depending on the boost controller setting. Just not lower than 7lbs.
Old Jun 29, 2004 | 08:23 PM
sneakypete's Avatar
Default Re: Does this look right? pics (braintree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by braintree &raquo;</TD></TR><TR><TD CLASS="quote">The size of the spring limits how LOW you can go. If it's a 7lbs spring, you can boost higher than that depending on the boost controller setting. Just not lower than 7lbs.</TD></TR></TABLE>
I don't want to go lower then 7 psi. I want to run 7 psi on the low boost setting and my higher boost setting I want to run 12 psi. Right now I have both dials turned all the way down and its boosting past 7 psi, its going to 10 psi. The only other way I can see hooking it up would be to use the top port of the wastegate.
Old Jun 29, 2004 | 09:38 PM
Mr. Softee's Avatar
try running the line to the WG straight from the IM to see that the WG is indeed the spring you think it is.
Old Jun 30, 2004 | 12:49 AM
egturbo's Avatar
arent u supposed to hook up another tube from the turbo to the boost controller? i think thats what i had to do with my prefec b
Old Jun 30, 2004 | 03:32 AM
ScrapinSi's Avatar
Default Re: Does this look right? pics (egturbo)
If I recall, you are supposed to leave the "low boost hose" to the side port, then put the "high boost hose" in the upper port.
Right?
Old Jun 30, 2004 | 05:54 PM
sneakypete's Avatar
Default Re: Does this look right? pics (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">try running the line to the WG straight from the IM to see that the WG is indeed the spring you think it is.</TD></TR></TABLE>
I know for a fact that is a 7 psi spring. The car has been boosted for almost two years. I had an old greddy tvvc boost controller hooked up before this and when I turned it all the way down it only went to 7 psi. Plus when I first boosted the car I didn't have a boost controller and it only went to 7 psi.
Old Jun 30, 2004 | 05:56 PM
sneakypete's Avatar
Default Re: Does this look right? pics (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">If I recall, you are supposed to leave the "low boost hose" to the side port, then put the "high boost hose" in the upper port.
Right? </TD></TR></TABLE>
If you do that how can the boost controller see boost? There isn't a low boost hose and high boost hose. There is only one hose coming out from the unit.
Old Jul 1, 2004 | 04:51 PM
ScrapinSi's Avatar
no.. you run a line from the compressor to the side port, then another from the compressor to the boost controller to the top port.
Old Jul 1, 2004 | 04:54 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">no.. you run a line from the compressor to the side port, then another from the compressor to the boost controller to the top port. </TD></TR></TABLE>
Bingo
Old Jul 1, 2004 | 05:00 PM
Suprdave's Avatar
Default Re: Does this look right? pics (Dr Pooface)
Thats how you run a Electronic with a Stepper Motor...but that Turbosmart is different. I had the same problem when we put one ona car...6psi spring yielded 9psi. So were going to try a lower spring...like a .3\.4bar...should put us where we want...6psi low\10psi high.
sneakypete's Avatar
I see. Thats what I was going to try next. However, I don't have a nipple of my compressor. So I'm just going to run it from an intake source.
Like this:
Old Jul 2, 2004 | 06:44 PM
sneakypete's Avatar
I tried it that way and it still creeps to 12 psi. Maybe thats why everyone runs turboxs dual stage boost controllers. I've tried everything and I just can't get this thing to work. Any other suggestions?
Old Jul 2, 2004 | 07:20 PM
onlinehost's Avatar
have you called the manufacture of the product to see what they say about your problem it sounds like it might be a easy fix but i could be wrong.
Old Jul 2, 2004 | 07:28 PM
sneakypete's Avatar
Default Re: Does this look right? pics (onlinehost)
I emailed them and they sent me 3 diagrams of how it should be setup. I tried all three and got the same results everytime, over boosting.
Old Jul 2, 2004 | 08:28 PM
Drew Peacock's Avatar
So are you getting you pressure source from the inlet mani? The time it take the air to travel through the long vaccum line could cause over boosting does it spike to 12psi and then drop or hold 12psi right through?
Old Jul 2, 2004 | 08:31 PM
sneakypete's Avatar
Default Re: Does this look right? pics (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">So are you getting you pressure source from the inlet mani? The time it take the air to travel through the long vaccum line could cause over boosting does it spike to 12psi and then drop or hold 12psi right through?</TD></TR></TABLE>
I don't know, I'm only tuned to 13 psi so when it gets around that area I let off. I didn't have any problems with the manual hks boost controller that I was running before this. Yes I'm running it from the intake manifold source.
Old Jul 2, 2004 | 08:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakypete &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know, I'm only tuned to 13 psi so when it gets around that area I let off. I didn't have any problems with the manual hks boost controller that I was running before this. Yes I'm running it from the intake manifold source.</TD></TR></TABLE> If your tuned to 13 and your only going to 12psi I would keep my foot down and see, its pretty dangerous trying to look and drive though I know. Looking at your pics its looks like your turbo does have a pipe coming out for a pressure source or am I seeing things? Also try turning the boost controller up a few clicks I have heard of people turning them to far down and getting overboost.. Goodluck.
Old Jul 2, 2004 | 08:46 PM
sneakypete's Avatar
My turbo doesn't have a source to tap from. I'll try turning it up a couple of clicks and see what happens. Thanks
Old Jul 2, 2004 | 09:25 PM
cheapturbolines.com's Avatar
Just curious, but do you have any problems w/ oil leaking from your return line? I have seen some problems w/ this when the turbo center housing is not clocked parrellel w/ the ground.
Old Jul 2, 2004 | 09:33 PM
sneakypete's Avatar
Default Re: Does this look right? pics (cheapturbolines.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheapturbolines.com &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, but do you have any problems w/ oil leaking from your return line? I have seen some problems w/ this when the turbo center housing is not clocked parrellel w/ the ground.
No problems to speak of yet. Its been almost two years with the setup.
playahwitgame
Jul 6, 2006 01:53 PM
AZNracerx1989
Jul 18, 2005 10:12 AM
ek9vboi2
Jul 18, 2004 08:14 PM
yusoslo
Jul 12, 2003 08:01 PM
TurboIntegra
Aug 11, 2001 01:23 PM
