help replacing hose...
Old Apr 7, 2003 | 12:37 AM
vti-R's Avatar
Default help replacing hose...
does anybody know a good way to replace the bypass outlet hose without causing alot of coolant spill.
thanks.
Old Apr 7, 2003 | 04:46 AM
im_poor's Avatar
Default Re: help replacing hose... (vti-R)
thanks.
how much is a lot of coolant to you??
Old Apr 7, 2003 | 05:50 AM
Chubz's Avatar
Default Re: help replacing hose... (impoor)
drain the coolant
Old Apr 7, 2003 | 04:05 PM
vti-R's Avatar
no it just that the hose is behind the distributor and near the throttle body so i dont want coolant to spray everywhere because its gonna hard to clean up. think im gonna have to drain the coolant.
Old Apr 7, 2003 | 04:15 PM
Chubz's Avatar
try and pinch the hose, but im betting money that you will spill coolant, ive done a bagillion times and I spill coolant like an Iraqi Intelligance officer spills info to US troops
Old Apr 7, 2003 | 05:05 PM
vti-R's Avatar
Default Re: help replacing hose... (Freakzilla)
would there be any problems spiiling coolant around that area.
Old Apr 8, 2003 | 05:56 AM
Chubz's Avatar
possible noticeable coolant loss, (could over-heat) and if it does spill make sure you clean that area or its gonna reek when the engine gets hot
Sushpreme o
Honda Civic (2006 - 2015)
Nov 29, 2018 11:37 AM
SpazMan
Jun 12, 2008 10:22 AM
