DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS?
Old Jan 17, 2002 | 06:34 PM
spoolin342's Avatar
Default DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS?
HOW DOES IT DETECT A MISFIRE?
Old Jan 17, 2002 | 07:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (spoolin342)
Are you getting a misfire code, and if you are in what cylinders?
art
turboex's Avatar
im guessing knock sensor. dosent hear the engine fire corect
Old Jan 17, 2002 | 07:27 PM
spoolin342's Avatar
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (Arturbo)
YEA IAM HOLES 3&4
Old Jan 17, 2002 | 07:34 PM
Arturbo's Avatar
Better than steak
25 Year Member
Are you having a lumpy idle?
Old Jan 17, 2002 | 08:28 PM
lazyvietboi's Avatar
stop the caps dude.
Old Jan 17, 2002 | 09:06 PM
spoolin342's Avatar
yea but only 1-3 times
Old Jan 17, 2002 | 09:13 PM
GSRwBOOST's Avatar
do a compression test.. the only time i got the misfire code was when i blew the ringlands out...
tell us what the results are.... the knock sensor i dont' think is too sensative...??
could be wrong.. but i think it takes a lot for it to detect knocking and when it does, there's not much it does to prevent it..??
Old Jan 17, 2002 | 09:41 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (GSRwBOOST)
This is what I recomend you do. First, put the fuel regulator back to stock in other words take the FMU out of line. Remove the line off of the FMU and run the line back into the regulator like it came from the factory.
Next, reset the ECU and see if you still get the codes. If you dont then its the fmu. Also, check your fuel pressure if yoiu can.
art
Old Jan 18, 2002 | 12:06 AM
dustin's Avatar
Check your plug wire firing order... reverse a couple and you'll get lots of misfires
Dustin
Old Jan 18, 2002 | 07:01 AM
G's Avatar
G
I believe the misfire is detected through the o2 sensor readings.
Old Jan 18, 2002 | 07:04 AM
DirtyLude's Avatar
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (dustin)
The OBD II Honda ECUs detect a misfire by fluctuations caused in crank speed due to one cylinder not firing. It checks crank speed by a 12 tooth trigger mounted to the crank (Crankshaft Position Sensor).
Old Jan 18, 2002 | 09:18 AM
dbman96's Avatar
New User
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (DirtyLude)
There's definitely something not sparking right or you've got a siezed fuel injector or something.
Old Jan 18, 2002 | 11:59 AM
sparkz's Avatar
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (dbman96)
Try changing your spark plugs and regapping them
Old Jan 18, 2002 | 01:56 PM
Xerxes's Avatar
New User
So if you're using an MSD soft touch rev limiter, won't it think that your rev limiting is also a misfire?
-Xerxes
Old Jan 18, 2002 | 07:21 PM
turboex's Avatar
Default Re: DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS? (Xerxes)
im pritty sure its the knock sensor
antballs420
Feb 20, 2006 06:35 PM
tek_civic
Aug 11, 2003 09:59 PM
Chrome Pipes
May 23, 2003 10:01 AM
jspek29
May 3, 2003 07:08 PM
sporkcrx
Nov 1, 2002 04:43 PM
