Max-Rev DP fitment problem
Old Jul 1, 2002 | 04:15 PM
DOHCarp's Avatar
Default Max-Rev DP fitment problem
Hey, I just got a max rev manifold downpipe and turbo combination for my B16 and when I went to put the downpipe on it angled to the ground and comes within 2 inches of scrpaing the ground.
Has anyone else had any problems with this combination before?
If their is an easy fix for this problem someone please let me know. thanks!
Old Jul 1, 2002 | 04:16 PM
dustin's Avatar
Default Re: Max-Rev DP fitment problem (DOHCarp)
cut, reweld
Old Jul 1, 2002 | 05:02 PM
93LSivic's Avatar
Make sure you have all the manifold--->turbo---->dp all loose when fitting on the car. There should be good amounts of movement at the dp. This is what I had to do.
Old Jul 1, 2002 | 05:08 PM
DOHCarp's Avatar
Default Re: Max-Rev DP fitment problem (93LSivic)
I had all bolts tight and loose....just couldn't seem to get the DP up any higher.
Old Jul 1, 2002 | 05:50 PM
01geeser's Avatar
New User
my downpipe angles towards the passenger side. it hits the flywheel cover bolts.
Old Jul 2, 2002 | 08:01 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I have the same kit, and if it happened to you, it's probably goign to happen to me. I should have gone Greddy.
Old Jul 2, 2002 | 08:15 AM
dustin's Avatar
Default Re: Max-Rev DP fitment problem (Snafu-Si)
downpipes never fit right.
Old Jul 2, 2002 | 08:19 AM
Trigun's Avatar
my dp is angled too, it hit's the flywheel cover a tad.
the muffler shop welded a new flange on the dp but not straight on .. more of like an angle so i could connect my cat without bending the dp or cat or exhaust. the aftermarket cat i got also has 2 flanges welded at an angle so it would connect to the exhaust straight. it's hard to explain but hey, it works.
Old Jul 2, 2002 | 08:43 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Max-Rev DP fitment problem (dustin)
You got that right.
art
Old Jul 2, 2002 | 11:26 AM
BROOD's Avatar
cut, reweld
Yep, even bolt-on turbos need alittle encouragment sometimes.
JHipps
Oct 2, 2013 02:57 AM
Blove1991
Apr 16, 2012 07:42 AM
boosteddb8904
Feb 1, 2008 09:00 AM
ComputerJLT
Welding / Fabrication
Oct 14, 2005 12:30 AM
AirWaveGT
Dec 1, 2004 11:42 AM
