do you suggest using a walbro 255?
Old Feb 27, 2005 | 10:39 AM
mike93eh
Guest
Posts: n/a
Default do you suggest using a walbro 255?
im getting a greddy turbo kit with intercooler and bov this week and was wondering if you suggest i get the walbro 255 fuel pump. after doing alot of searching on here, ive noticed alot of people have problems with it. and since ill be stay between 5.5psi and 7psi, do i need one? thanks.
Old Feb 27, 2005 | 10:56 AM
mrbsponge's Avatar
i always recommend it, it cant hurt, it can only hurt it if you leave it and it fails
Old Feb 27, 2005 | 10:58 AM
mike93eh
Guest
Posts: n/a
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i always recommend it, it cant hurt, it can only hurt it if you leave it and it fails</TD></TR></TABLE>
well after reading all the searched posts on here, it obviously CAN hurt things...just wondering if its really need with my setup and worth the headaches..
Old Feb 27, 2005 | 11:20 AM
N20civicB18's Avatar
Default Re: (mike93eh)
i have probably 25,000 miles on mine and about half of that was with a 12:1 FMU on my turbo setup with 12lbs of boost and I never had one problem with the pump, also it took no more then a half hour to put in
Kyle
Old Feb 27, 2005 | 12:01 PM
DefiantGSR's Avatar
Default Re: do you suggest using a walbro 255? (mike93eh)
are you going to use a FMU? I hope not. But if you are, you're supposed to use an inline fuel pump.
If not, at 7 psi..dont' sweat it. I hope yuo're getting larger injectors than those dinky 3100cc greddy injectors.
Old Feb 27, 2005 | 01:54 PM
mrbsponge's Avatar
problems dont come form the 255 it comes from the 255hp, and all of those problems are from people who really didnt need an HP in the first place and only have the stock regulator and cant bring the pressure down
Old Feb 27, 2005 | 03:40 PM
SoEvoL's Avatar
i have a 255, i dont have any problems at all. been about a month since ive installed it on my jrsc setup
Old Feb 27, 2005 | 03:44 PM
drvfast's Avatar
Yes. I have been using one for 1 year and it works great.
Old Feb 27, 2005 | 04:03 PM
Dunc's Avatar
BCICAN
Default Re: do you suggest using a walbro 255? (drvfast)
hmm...I haven't heard anything bad about the 255. I've been using one for the last 15,000miles at 13-15psi and still working great.
Old Feb 27, 2005 | 04:10 PM
Quad-Damag's Avatar
Default Re: do you suggest using a walbro 255? (Dunc)
1 year on mine, works great, good cheap pump
easy *** install
5 mins if u don't have backseats in
Old Feb 27, 2005 | 04:46 PM
mike93eh
Guest
Posts: n/a
yea i know the install is easy. im not talking about the 255 high pressure one though. ill be using greddys fmu at 7psi and stock injectors. the kit doesnt come with injectors. this is going on my 93 hatch. i know getting the pump shouldnt hurt anything, but is it really need for 7psi?
Old Feb 27, 2005 | 04:59 PM
Bspec18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">problems dont come form the 255 it comes from the 255hp, and all of those problems are from people who really didnt need an HP in the first place and only have the stock regulator and cant bring the pressure down</TD></TR></TABLE>
I've used the walbro 255hp and an FMU on 10psi never had any problems. Only reason i'm replacing it because i upgraded to stand-alone.
Old Feb 27, 2005 | 05:06 PM
Luke J's Avatar
Default Re: (Bspec18)
The walbro 255 works fine, If I was you I would put it in. Plus they are only like $79..........
Old Feb 27, 2005 | 09:35 PM
SoEvoL's Avatar
Default Re: (Lucky925l)
i ran 5psi, at first then upgraded to 11+, same fuel pump, causes no problems, had the JR Fmu, going hondata.
Old Feb 27, 2005 | 09:42 PM
_Cyclone_'s Avatar
Default Re: (JDMCrx89)
I heard rumors of them being very noisy... is there any truth to this?
Old Feb 27, 2005 | 09:53 PM
Quad-Damag's Avatar
Default Re: (CycloneBlue_1.6EL)
ya mine is kinda loud
Old Feb 27, 2005 | 09:54 PM
PrettyLude's Avatar
it will whine as any other aftermarket fuel pump will
Old Feb 27, 2005 | 09:58 PM
Race Egr's Avatar
Default Re: (PrettyLude)
while on the fuel system what do most guys pushing 500whp run? and how much hp is the 255 good for?
Rubixcu7
Jul 1, 2005 05:43 AM
civproject14
Dec 19, 2004 10:07 PM
sway892
May 17, 2004 04:35 PM
IntegraBoi
Jul 18, 2002 08:40 PM
sushibug
Apr 5, 2002 09:47 AM
