do i need to re-tune?
Old Feb 18, 2008 | 05:05 PM
JDMeg95's Avatar
Default do i need to re-tune?
i got my car tuned without my bumper on cuz i didnt have one, now i found that the piping is in the way and wont fit right.....if i cut the piping shorter and make minor adjustments do i need to re-tune? thanks
Old Feb 18, 2008 | 05:43 PM
KillAHonDa's Avatar
Default Re: do i need to re-tune? (JDMeg95)
i dont think u would need a re-tune for that
Old Feb 18, 2008 | 05:46 PM
1llmatic's Avatar
New User
why not cut the bumper?
Old Feb 18, 2008 | 06:12 PM
boostedb20z's Avatar
im a tuner and i would say yes just to make sure but im one of them people that very picky the way my motors run. but psi is psi
Old Feb 18, 2008 | 06:56 PM
blinx9900's Avatar
Default Re: (boostedb20z)
depends how much your cutting or if your chaning sizes, most likely i would say no you dont need a retune...
Old Feb 18, 2008 | 08:33 PM
JDMeg95's Avatar
Default Re: (blinx9900)
well i was thinking that by shortening the pipe i would be affecting spool time and getting boost at a little lower rpm? maybe creating a lean condition for a second before the ecu catches up? i dont want to re tune......i just spent 400 bucks on a full tune
Old Feb 18, 2008 | 09:12 PM
blinx9900's Avatar
Default Re: (JDMeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMeg95 &raquo;</TD></TR><TR><TD CLASS="quote">well i was thinking that by shortening the pipe i would be affecting spool time and getting boost at a little lower rpm? maybe creating a lean condition for a second before the ecu catches up? i dont want to re tune......i just spent 400 bucks on a full tune</TD></TR></TABLE>
a retune should be MUCH cheaper cause they would only make minor changes, if your in doubt just do it, it should be $100 ish or so... or better yet call the tuner and ask there opinion...
Old Feb 18, 2008 | 09:17 PM
90sedan's Avatar
I see that you are from Puyallup, who tuned your car? But if they are "minor" adjustments, you should be fine without retuning it.
Old Feb 18, 2008 | 10:31 PM
JDMeg95's Avatar
Default Re: (90sedan)
speedfactory tuned my car
Old Feb 18, 2008 | 11:00 PM
JDMeg95's Avatar
Default Re: do i need to re-tune? (KillAHonDa)
any more opinions?
Old Feb 19, 2008 | 12:44 AM
140sx's Avatar
no, i ran a front mount in my s13 then did a v mount shorting the piping by like 5ft, there was maybe a spool time differance of 50rpm. there is no reason why you should retune your car.
Old Feb 24, 2008 | 06:27 PM
.PLUMMM's Avatar
Default Re: do i need to re-tune? (1llmatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1llmatic &raquo;</TD></TR><TR><TD CLASS="quote">why not cut the bumper?</TD></TR></TABLE>
very true
Old Feb 24, 2008 | 06:44 PM
hellakapps's Avatar
Default Re: do i need to re-tune? (.PLUMMM)
call james and ask him, and like said earlier he is not going to charge you as much since he will only have to tweak your tune, and i would get it done so if nothing more at least you will have peace of mind
em2ssm02
11
Nov 10, 2006 09:08 AM
Mikey3000
Apr 16, 2006 10:49 AM
RACEPAK
Aug 10, 2005 02:10 PM
98_4drCivic
May 27, 2005 08:54 AM
yorktonite
Jul 12, 2002 02:25 PM
