Do I need an FPR?
Old Oct 15, 2007 | 08:09 AM
Dartanian's Avatar
Default Do I need an FPR?
So I have my new setup on (SLS shorty, GT3255, 6.5 psi until block is built) and I have been messing around with Neptune RTP to get my 880's running well. All the basemaps I upload are waaaaay too rich in pretty much every portion of the map, so I end up running an incredibly low duty cycle. This leads me to believe that my fuel pressure is too high. I am running a Walbro 255 pump, BTW. I haven't measured the fuel pressure, so I don't really know if it is too high or not. Has anyone else experienced this?
Old Oct 15, 2007 | 08:48 AM
Topdawgg's Avatar
ive got 1000s to idle perfect with stock rail and stock FPR...
got a wideband to see what exactly your fuel is like?
Old Oct 15, 2007 | 08:52 AM
Dartanian's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">ive got 1000s to idle perfect with stock rail and stock FPR...
got a wideband to see what exactly your fuel is like?</TD></TR></TABLE>
Yeah, it is in the low 11's, high 10's once I get out of closed loop. I am pretty much just smoothing out fuel cut and idle, so I am driving it around slowly and out of boost.
Old Oct 15, 2007 | 09:20 AM
Topdawgg's Avatar
low 11s in boost? or low 11's just driving around?
cause thats way to rich for just driving around out of boost..
Old Oct 15, 2007 | 01:38 PM
meowpox's Avatar
when i got a 255 lph walbro pump, my fuel pressure only went up a few pounds. the car ran fine on the stock map. you dont really need a fpr unless the duty cycle of your injectors is really high and you need more fuel when tuning.
Old Oct 15, 2007 | 01:46 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">low 11s in boost? or low 11's just driving around?
cause thats way to rich for just driving around out of boost..</TD></TR></TABLE>
It is in the 11's just driving around. Boost will send it well into the low 10's.
Old Oct 15, 2007 | 02:17 PM
SwappedTURBOegg's Avatar
so whats stoping you from taking some fuel out of it?
Old Oct 15, 2007 | 02:37 PM
Dartanian's Avatar
Default Re: (SwappedTURBOegg)
Nothing at all. I am just saying that every basemap is beyond pig rich and wanted to see if the fuel pressure was abnormally high causing this issue.
Old Oct 15, 2007 | 04:32 PM
dmotoguy's Avatar
Default Re: (Dartanian)
i think its your tune, not your fuel pressure.. man thats really rich.
Old Oct 15, 2007 | 04:43 PM
Topdawgg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
It is in the 11's just driving around. Boost will send it well into the low 10's.</TD></TR></TABLE>
way too rich for driving around... high 14's, really low 15s out of boost...
you dont need a FPR, just take some fuel out
Old Oct 15, 2007 | 04:46 PM
Dartanian's Avatar
you dont need a FPR, just take some fuel out</TD></TR></TABLE>
Alright, that is what I planned on doing anyway. Thanks.
Old Oct 15, 2007 | 04:51 PM
Topdawgg's Avatar
14.7 is ideal for cruisin... aim for that.. obviously its gonna take some time to get it perfect...
low 11's and 10s are good in boost... thats all..
just keep at it, it takes some work...
Old Oct 15, 2007 | 04:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">Nothing at all. I am just saying that every basemap is beyond pig rich and wanted to see if the fuel pressure was abnormally high causing this issue.</TD></TR></TABLE>thats wht its a "base" map. just take some fule out and listen to what Topdawgg said
Old Oct 15, 2007 | 05:22 PM
Topdawgg's Avatar
exactly...
some basemaps wont even IDLE when you first start up... if the injectors are big enough...
so why would that be different for the rest of the map?
Kr4nG
Sep 28, 2009 02:31 AM
blackeg
Jul 11, 2007 07:04 PM
clemsoncb7
Dec 18, 2006 08:46 PM
PowderB16
15
Mar 3, 2005 10:49 AM
B_1_8_hatch
Apr 23, 2004 02:22 AM
