do i need a fpr
Old Jan 28, 2006 | 11:11 AM
7808's Avatar
Default do i need a fpr
my friend keeps saying i will need a fpr, others tell me i do not, all of them have experience boosting civics so..
heres my set up:
chipped p28 w/ data logging probly gona run uberdata
dsm 450s w/resistors
stock motor and fuel pump d16y8
14b turbo with custom ghetto manifold
cca fmic
gona be running stock wastegate at stock setting 8psi i belive
Old Jan 28, 2006 | 11:42 AM
slodc2's Avatar
not if your using your stock fuel pump...but i would recommend an aftermarket one...when i put my walbro 255lph in my fuel pressure went up from 42psi to 60psi...i have the b&m fuel pressure modifier so i turned it down all the way and it would only go down to 55psi and no lower b/c of that fuel pump...so i had to drill a pressure relief valve in the fpr to get it down further
Old Jan 28, 2006 | 11:39 PM
EnzoSpeed's Avatar
Default Re: do i need a fpr (7808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">my friend keeps saying i will need a fpr,</TD></TR></TABLE>
Tell your friends to stop giving you bad advice.
Old Jan 29, 2006 | 12:21 AM
beerbongskickass's Avatar
Default Re: do i need a fpr (EnzoSpeed)
Your stock FPR will be fine... Just upgrade to a Walbro 255 and your good to go.
Old Jan 29, 2006 | 08:26 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: do i need a fpr (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Your stock FPR will be fine... Just upgrade to a Walbro 255 and your good to go.</TD></TR></TABLE>
255lph, High Pressure for the extra $10
Old Jan 29, 2006 | 08:29 PM
EnzoSpeed's Avatar
Default Re: do i need a fpr (integra_LSR)
Don't buy the HP!
Old Jan 29, 2006 | 08:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Don't buy the HP!</TD></TR></TABLE>
because..
Old Jan 29, 2006 | 08:42 PM
espanol's Avatar
i run stock fpr and stock ignition using dual fmu's and afc hack.
Old Jan 29, 2006 | 08:59 PM
red cx's Avatar
you really dont need a FPR.....but It would not hurt to get one anyway. You say that you will be running 8psi but sooner or later you'll want to turn it up. So a good aftermarket FPR would be a good idea.
Old Jan 29, 2006 | 10:49 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_LSR &raquo;</TD></TR><TR><TD CLASS="quote">
because..</TD></TR></TABLE>
Because then he actually WILL need an fpr.
Old Jan 29, 2006 | 11:02 PM
Because then he actually WILL need an fpr.</TD></TR></TABLE>
ive been debating whether the high pressure was worth it or not. i dunt want to change out my stock fpr either but other people think i should get the high pressure one too. even my tuner recommended i get high pressure.
::confused::
Old Jan 30, 2006 | 06:39 AM
Zakar's Avatar
isnt the low pressure unit for non fuel injected engines?
i always see everyone saying to get the HP pump
Old Jan 30, 2006 | 09:55 AM
Default Re: do i need a fpr (blue89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue89crx &raquo;</TD></TR><TR><TD CLASS="quote">
you really dont need a FPR.....but It would not hurt to get one anyway. You say that you will be running 8psi but sooner or later you'll want to turn it up. So a good aftermarket FPR would be a good idea.</TD></TR></TABLE>
The stock fpr is good up to like 500whp, so I think that's fine for most of us lol.
Old Jan 30, 2006 | 10:10 AM
I Have an STD's Avatar
wrenchin'
beerbongs, i think we told him this on homemadeturbo too. his username is WTF
dood, u need to just listen to us on HMT most of the people on this site DONT know what they are talking about. you all know who u are.
Old Jan 30, 2006 | 11:33 AM
tgreaves's Avatar
The stock fpr is good up to like 500whp, so I think that's fine for most of us lol.</TD></TR></TABLE>
I dont think you can put a hp figure on a regualtor.. If it can flow the amount of fuel out of it to keep the pressure then its good..
Guess im saying that the only thing that changes with more hp is the amount of fuel but under power your flowing less fuel through it since the injectors are using more..
So if your fpr can keep its intended pressure when flowing XXX amount of fuel at lower loads then your good..
Old Jan 30, 2006 | 12:11 PM
Default Re: do i need a fpr (tgreaves)
Well the only reason I put a number on it was because BH mentioned stock fpr's are good for under 500whp. I assume that means he has tuned quite a few 300-500whp cars with stock fpr's on them and they work. So with properly sized injectors it looks like the stock fpr is fine for pretty much all of us.
http://forums.evans-tuning.com/viewtopic.php?t=668
Old Jan 30, 2006 | 01:19 PM
Default Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">isnt the low pressure unit for non fuel injected engines?
i always see everyone saying to get the HP pump</TD></TR></TABLE>
exactly my point.
Old Jan 30, 2006 | 04:09 PM
EnzoSpeed's Avatar
Default Re: (integra_LSR)
Here was last week's walbro argument session:
https://honda-tech.com/zerothread?id=1493178
Conclude what you will from the argument, but what I know for sure is that you definitely don't need the HP for such an "HMT" setup.
91redteg
Dec 6, 2007 12:26 PM
oxSLEEPERxo
Dec 27, 2005 07:01 AM
gsrboost
Mar 7, 2005 12:24 PM
mengy007
Sep 2, 2004 11:38 AM
lowboost civ
Apr 23, 2003 06:46 PM
