Do Hasport munts break in?
Old Sep 22, 2006 | 06:17 PM
adictionbass's Avatar
Default Do Hasport munts break in?
Whats up guys. I have some hasport street/strip mounts that ive been running in my del sol for a little over 1000 miles. I went to the track for the first time tonight, and on the way home, noticed that my shifter would rock back and forth as i hit or let off the gas. Pop the hood when i got home, everything looked good, but now when i give it some throttle, the motor rocks back (like with most cars).
Until today the motor wouldnt budge, now it has a decent amount of rock to it. So do hasport mounts actually break in (loosen up more than the way they come) or do i have another problem?
Old Sep 22, 2006 | 07:00 PM
komat's Avatar
Default Re: Do Hasport munts break in? (adictionbass)
they do break in but shouldnt be rocking your motor
i put 4000miles on my mounts. motor didnt even move when iw as at the dyno doing 420hp/312tq
Old Sep 22, 2006 | 07:24 PM
a1320addict's Avatar
Default Re: Do Hasport munts break in? (komat)
Check the torque specs on all mount hardware.
Old Sep 22, 2006 | 07:27 PM
sycamore
Guest
Posts: n/a
Default Re: Do Hasport munts break in? (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Check the torque specs on all mount hardware.</TD></TR></TABLE>
Old Sep 23, 2006 | 04:07 AM
Blind-Fashion's Avatar
I'd check and see if the rear T bracket is tight.
Old Sep 23, 2006 | 12:04 PM
Default Re: (Blind-Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind-Fashion &raquo;</TD></TR><TR><TD CLASS="quote">I'd check and see if the rear T bracket is tight.</TD></TR></TABLE>
ha ha right... so that 8" bolt that runs through the T bracket and the mount, yea thats just gone. I guess it vibrated loose, but everything was put together with an impact, so i guess ill use some lock tight this time
fromthesun_93
Mar 23, 2012 11:20 AM
saemoonyang
13
Nov 9, 2010 06:14 PM
rorik
Jun 23, 2008 10:31 AM
lurkin' eg
Nov 30, 2007 03:48 PM
DFW
Mar 23, 2007 03:14 PM
