DIY wide band O2
New User
DIY wide band O2
I found this on the supra board. http://www.techedge.com.au/vehicle/wbo2/default.htm
Re: DIY wide band O2 (dustin)
Ok, I ordered the PCB, parts kit, and the display meter.
I think Crescent Kao built this kit too.. I hope it'll work with the wideband option in hondata.
Dustin
Dustin
damn Dustin what do u do for a living..??
u inherit some money or something..??
i see u buying a sh/t load of stuff...lol
let know how it works..!!
[Modified by Giuseppe, 8:45 AM 2/7/2002]
Re: DIY wide band O2 (Giuseppe)
It's like $70 USD, and I was looking at it a couple weeks ago Don't have the $$ right now to get the sensor, but I'll have enough fun trying to assemble it with my sub-par electronics skills (or lack thereof).. since it's a DIY kit.
Dustin
Dustin
you will need very good electronics skills to construct the kit
It's NOT a kit for beginner hobbyists
Remember, the FMD is a DIY kit and very good electronics
construction skills are required to successfully make it work.
That said, the kit may be DIY, but the results and operation should be totally professional.
geez i wonder if a one eyed shoe salesman could put this kit
together...
[Modified by Giuseppe, 9:03 AM 2/7/2002]
[Modified by Giuseppe, 9:04 AM 2/7/2002]
Time to amass some electronics skills
how hard could it be to weld in those circuits, my
kit brother biult a mini cicruit for school(which he had to test),
so why the heck couldn't competent adult not be able to do it...?!?!?!
eheh Im in Australia... and was thinking of gettin the motec PLM... bc out here we sell them for 1200Aust which is like 600$us or so.
But even this DIY-WB seems cheep.. might have to invest in it...
dustin let us know how ya proejct goes... also i belive if you can install a hondata ya self.. you can easly make this DIY-WB .
Regards James
Regards James
Re: DIY wide band O2 (GruvyTune)
sorry to jump off the subject about the wide band o2 sensor. Justin how do you like your thermal exhaust and do you have a 3" downpipe? how far are you from Pittsburgh,Pa just curious cause i would like to meet up with some people to check out there rides. hope to have my turbo charged si on the road in 2 months. After spending $12,000 on a built motor and rebuilt turbo it's that time to start enjoying my car once again.
Re: DIY wide band O2 (92SiTurbo)
Fark 119$ for the Sensor thats ultra CHEEEP !!!
hummm u gota let us know how ya went with it.. and also im guessing if its the same sensor as the motec plm it will plug stright uptp the hondata correct ???
New User
Re: DIY wide band O2 (BLKCRX)
um... the hondata doesn't actually READ the wideband O2 sensor, does it? I was under the impression hondata just SELLS the PLM as an accessory for tuning. I've been wrong before though.
Electronics skills? Hell, if you've chipped a PS2 you should be able to manage this, right?
Re: DIY wide band O2 (dbman96)
Hondata can use a wideband O2 sensor and will show you how far you are over your target lambda in a run ... it also has an 'autotune' mode that changes fuel output according to lambda...
Dustin
Dustin
um,
the hondata can log the wideband. you just connect the output of the wideband unit and run it into your signal input on your O2 sensor harness back to the ecu. you can program the hondalogger for various sensors. It comes preloaded with tables for the PLM motec. you can enter the table for the diy unit since you can dowload the graph from that site. DUDES, for the money, its worth it. I searched the diy board listserve and it seems like a great sensor/control unit. Obviously, I bought one.
torin
torin
SpyderZEX
07-29-2003 11:54 AM
