Divided Manifold vs Not Divided manifold
Old Jan 30, 2003 | 08:23 AM
K20  EG's Avatar
Default Divided Manifold vs Not Divided manifold
what are the pros and cons of using divided turbo manifolds and the pros and cons of using single plane manifolds?
Old Jan 30, 2003 | 08:42 AM
Boltz's Avatar
Default Re: Divided Manifold vs Not Divided manifold (RevhardEG)
i dont know much but i can try and help, the split manifolds try to make use of the cylinder firing sequence, properly designed should give the exhuast gases a "pulse" effect on the way to the turbo, i guess these pulses are far superior to a log stlye manifold where all the gasses gather into one...
my 02
Old Jan 30, 2003 | 08:44 AM
Boltz's Avatar
Default Re: Divided Manifold vs Not Divided manifold (Civic420)
so i guess the pros would be a much better manifold and design, and better throttle response, and quicker boost, being a piece of art, etc...
cons would be cost, and i doubt youll ever find one for a car with a/c or **** like that
Old Jan 30, 2003 | 11:03 AM
paulzy's Avatar
THe divided manifold does do with exhasut pulses and firing order to help with spool up, but the funny thing is, Presicion said that the tang undivided will spool better tahn teh divided housing
Old Jan 30, 2003 | 11:53 AM
Full-Race Javier's Avatar
Default Re: Divided Manifold vs Not Divided manifold (1320development)
in theory and on paper, the divided housing pulse converter seems like a good idea. but in real life, i doubt it makes a noticeable difference. if it did, then why arent the fast cars using them?
Old Jan 30, 2003 | 10:13 PM
K20  EG's Avatar
ya i was thinking the same thing ..but my manifold seems to do the job right...its a question i had to ask
the pulse manifold makes sense to me ..but since i have a Turbonetics race gate ..with a 9 lb spring ..and my waste gate dumps off only 2 cyls...should i get a heavier spring..to increase turbo response ..or just adjust my boost controller WG duty ??
Old Jan 30, 2003 | 10:24 PM
paulzy's Avatar
just redirect your manifold...HOw I designed my manifold on paper waiting for moeny to get the actual metal , I'm dumping the WG from 2 areas of the collector. Similar to some of the bigger named racers out there
Old Jan 30, 2003 | 10:34 PM
Full-Race Geoff's Avatar
Using a single 4-1 merge collector will be more effective then a 4-2-1 design. it will make more power and spool faster.
lkailburn
Welding / Fabrication
Jul 31, 2005 11:57 AM
aznxmike
Feb 4, 2005 11:18 AM
justinbailey
Apr 29, 2004 12:43 PM
J2turbo21
Dec 26, 2002 06:24 PM
