Distributor acting up need advice!
Old Jul 17, 2006 | 01:55 PM
iBrandon's Avatar
Default Distributor acting up need advice!
Ok, lately my car has been misfiring and the rpm gauge is very very jumpy in high boost...so i decided to replace the stock distributor...problem is acura wants $500-$600 to do so in parts....No way! Usually what do you guys replace in your stock distibutor?? The ignitor alone is aroudn 230 bucks....coil is like another 150 or so...and rotor is around 25-30 bucks....Is there another alternative? I was looking at the MSD billet distributors and they look fairly decent...can it be used without the msd ignition system? meaning can i just use an exteranal coil and their distributor....my power goal is 600 hp on race and 500 on pump...
Any advice will be greatly helpful...i dont see myself spending 500-600 on a stock distributor....thats crazy!
-brandon-
Old Jul 17, 2006 | 02:05 PM
abnaasefmb's Avatar
Default Re: Distributor acting up need advice! (iBrandon)
i picked a obd1 dizzy at autozone for $150. but i wouldn't put it in a 600hp engine.
ignitors are the same if you oick up one for say a 92 civic dx, it will be way cheaper and works just as well. i can't remember if the coil is the same.
Old Jul 17, 2006 | 02:06 PM
abnaasefmb's Avatar
Default Re: Distributor acting up need advice! (abnaasefmb)
pull your cap and check for the red dust of death. if no dust you should be able to just change the ignitor cap and rotor
Old Jul 17, 2006 | 02:12 PM
iBrandon's Avatar
yeh...those autozone or orielys ones i wouldnt trust either on this engine...alot of people say go stock ignition...thats why im trying not to use msd if possible...but **** parts for oem are expenSIVE! Also if i buy a used one...from an old distributor any way of testing if the ignitor is good or bad?
Old Jul 17, 2006 | 02:13 PM
iBrandon's Avatar
red dust? never heard of that...
Old Jul 17, 2006 | 02:52 PM
alpha's Avatar
I have replaced my rotor, rotor screw, coil and ICM but I got them at cost. A little cheaper but not cheap. The MSD Pro Billet is great. It's on backorder though
Old Jul 17, 2006 | 06:14 PM
iBrandon's Avatar
Default Re: Distributor acting up need advice! (0x64)
anyone else have experience with the msd billet?
Old Jul 18, 2006 | 09:15 AM
alpha's Avatar
https://honda-tech.com/zerothread?id=1585765
Old Jul 18, 2006 | 10:09 AM
86si's Avatar
the red dust is from the bearing starting to bind and seize. you can buy a housing from honda/acura for about 250.00. usually the ignitors won't cause a miss but the coil will. Pm me if you want a price on a brand new dizzy from honda. i can help you out.
xlusiveracer
44
Apr 3, 2018 04:59 PM
plugger
Feb 23, 2012 07:17 PM
313hitman
Mar 1, 2009 04:37 PM
00_EM1
Aug 15, 2007 10:13 PM
dyg2001
Feb 24, 2004 09:38 AM
