direct port nitrous setups...
Old Apr 17, 2005 | 10:26 PM
  #26
JDMorgan's Avatar
Default Re: (Phase Change Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">Well I can state for a fact that the lines on Jspin's system wern't right the first time. Someone didn't tell me that there was an oil filter back there to watch out for...
Stainless line really isn't too expensive, its only a couple bucks a foot. They key is to buy it in a long straight chunk from a good hydraulics store instead of the lame 1' lengths the nitrous suppliers sell. You have a lot less waste this way.</TD></TR></TABLE>
i didn't relize it when i drilled for the nozzles, then i decided to cut the box in half. now i just have to convince my bro to tig weld it back together. should you try to keep the lines equal length?
Old Apr 19, 2005 | 04:48 PM
  #27
Phase Change Racing's Avatar
Default Re: (KraZEtEggIE)
The debate over equal length lines continues but the general consensus is that it doesn't matter. The increase in resistance to flow in a longer line is irrelevant compared to the restrction of the jet itself. I Personally don't worry about equal length lines. Running biased line lengths between the nitrous and fuel side it quite important (ie longer nitrous lines than fuel lines). Its one of the reasons my systems don't grenade engines.
Old Apr 19, 2005 | 06:20 PM
  #28
Blanket Jackson's Avatar
Wheres Timmay, he has a setup for sale that was on an H22 with Direct-Port that ran 12.0 in Boise. I believe there is pics in his for sale post.
Old Apr 19, 2005 | 10:21 PM
  #29
TURBOFTW's Avatar
Default Re: (HONDAofPOKY)
Heres a my setup:
ITR shortblock
stock gsr head
itr cams
competion sprug 4 puck clutch
rmf equal length header
k-teller stainless steel 2-1/2 full exhaust
NX directport 80shot (22 nitrous jet, 16 fuel jet)(nice and rich)
rc 370s (soon)
xs enginering ecu
13deg base timing
walboro 190lph
fuel pressure set at 46psi with stock injectors im gettin a plx300 wideband shortly along with my injectors
Old Apr 20, 2005 | 01:02 AM
  #30
wolve's Avatar
Default Re: (h22dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22dude &raquo;</TD></TR><TR><TD CLASS="quote">Heres a my setup:
13deg base timing
how can you vary the nitrous/fuel ratio to suit a non-grenadable engine
how's the engine running with 13 degrees of timing, done some the dyno's on the powerloss?
what's your c/r?
just want to know because i'm piecing together a safe nitrous set-up without sacrificing too much na-power
Old Apr 20, 2005 | 01:17 AM
  #31
SiR831's Avatar
Default Re: (wolve)
Old Apr 20, 2005 | 05:56 AM
  #32
Default Re: (SiR831)
Keep in mind that a richer tune is not necessairly a safer tune. The safest tune you can run is a good tune somewhere in the 5:1 nitrous:fuel ratio range. I usually dial all of mine in around 5.5:1 these days. I've run up to 7:1 on hyperutectic pistons without a problem but thats a little out of the "safe" range hehe.
Old Apr 20, 2005 | 06:32 AM
  #33
HondaTechIsTheGay's Avatar
Old Apr 20, 2005 | 09:06 AM
  #34
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that a richer tune is not necessairly a safer tune. The safest tune you can run is a good tune somewhere in the 5:1 nitrous:fuel ratio range. I usually dial all of mine in around 5.5:1 these days. I've run up to 7:1 on hyperutectic pistons without a problem but thats a little out of the "safe" range hehe. </TD></TR></TABLE> keep in mind both are completely pressure dependent.
Old Apr 20, 2005 | 11:09 AM
  #35
TURBOFTW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wolve &raquo;</TD></TR><TR><TD CLASS="quote">
what's your c/r?
just want to know because i'm piecing together a safe nitrous set-up without sacrificing too much na-power </TD></TR></TABLE>
OK where to start i just got my setup finished all motor i was running 13.8 this is in a integra gsr with a/c and all, i just finished my nitrous setup i was going to run a 26 nitrous jet and 16 fuel jet which is a 100shot but instead i used a 22 nitrous jet just to make sure everything was rich until i got a wideband..anything lower then 13deg all motor was realllyyy sluggish, my compression is about 11.3:1.... Oh and with the setup i have im trapping right around 118
Old Apr 20, 2005 | 05:46 PM
  #36
Everything is dependent on pressure in the nitrous world. The ratios mentioned in my post were gained by bench flowing the system as I do with all of my high performance tunes. If the tune is in the ballpark before you head to the track you get to enjoy the day racing instead of leaning out a fat tune all day.
Old Apr 20, 2005 | 06:33 PM
  #37
FormulaGSR's Avatar
heres a question along these lines. I have all the **** for a direct port setup except for one problem. My nozzles spay from the side instead of the front like the ones in the pics here. I got the kit used and i have 8 of these nozzles. Is it gonna cause problems to use them? I cannt see why it would but eveyone runs the same nozzles and they are diff. from what i have so i thought i'ld ask.
Old Apr 20, 2005 | 06:34 PM
  #38
TURBOFTW's Avatar
Default Re: (FormulaGSR)
You have 8 nozzles?????
Old Apr 20, 2005 | 06:58 PM
  #39
NXLude's Avatar
probably a v8 kit. And there are 2 kinds of nozzles, down and side. For DP you want one that sprays outa the side otherwise your just spraying into the wall of the IM (bad)
Old Apr 20, 2005 | 07:59 PM
  #40
The nozzles you are referring to are Annular nozzles. These nozzles can work quite well in an import system but it takes some effort. They need to be angled into the intake steeper than 45 degrees. Which means some serious time put into tig welding a set of shallow bungs onto the intake. If you plumb them in perpendicular to the intake you will experience EXTREME fuel fallout. For simplicity a set of soft plume nozzles would be a lot nicer. I rarely use Annular nozzles in my systems but there are some situations where they are a godsend. like the intake on my lil 2.5L turbo dodge.
Old Apr 20, 2005 | 08:09 PM
  #41
SiR831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">Everything is dependent on pressure in the nitrous world. The ratios mentioned in my post were gained by bench flowing the system as I do with all of my high performance tunes. If the tune is in the ballpark before you head to the track you get to enjoy the day racing instead of leaning out a fat tune all day.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1219250
think you can help me out here?
Old Apr 20, 2005 | 08:20 PM
  #42
JDMorgan's Avatar
maybe you guys could share what jets nx recomends to each shot. i know the bigger ones but i am planning on starting with a 80 shot then moving up to a 120-140 shot. 140 is 31/18 right? anyone know 80, 100, and 120 by chance? also where is a good place to buy nx jets?
nubs
Mar 28, 2004 12:17 PM
Doug684
Jan 4, 2004 02:51 PM
KooK
Jul 9, 2003 03:35 PM
B19CivicHB
May 15, 2002 05:21 PM
