different housing?
Old Apr 26, 2003 | 10:45 AM
94dxt's Avatar
Default different housing?
are there larger compressor housings available for the td04h (sohc Greddy kit)? if so where?
Old Apr 26, 2003 | 10:59 AM
93LSivic's Avatar
Default Re: different housing? (94dxt)
Keep in mind a larger compressor housing is usually only neccesary when going with a larger compressor wheel. Its the turbine housing that is more commonly swapped out for a larger a/r to change the boost curve.
Old Apr 26, 2003 | 11:20 AM
94dxt's Avatar
Default Re: different housing? (93LSivic)
are there any larger a/r turbine housing on the market for my turbo, or a bigger compressor wheel? I'm not sure what I want to change out but I would like to know what my options are for this turbo.
As I understand it this turbo maxes out @ 15psi and eventually I will run close to that but I don't want to max out the turbo it won't last for ****
Old Apr 26, 2003 | 11:40 AM
93LSivic's Avatar
FWIW, looking at your sig you would just want a larger turbo overall. For the money spent upgrading the wheel and housing you could just get a new larger turbo. If your staying with the greddy manifold look into a 16G or something.
Old Apr 26, 2003 | 03:17 PM
94dxt's Avatar
what is the comparison between the 15g+16g (housing+wheel size, max boost)?
Old Apr 26, 2003 | 04:50 PM
filthy scarecrow's Avatar
15G
16G small
16G big
eg crunkmonster
Aug 17, 2006 09:26 AM
zchs21
Jan 23, 2006 10:08 PM
seanjohn81
Jul 8, 2003 01:00 PM
Acura_I-RS
Apr 13, 2003 06:42 PM
