different engine options....PLEASE HELP
Old Jan 1, 2003 | 06:56 PM
mitchb's Avatar
Default different engine options....PLEASE HELP
Ok which would be better ...i have 7k to blow.
option 1
b18c swap with
revhard turbo setup.
That will be pushing the limit as is.
option 2
b18b
pistons
rods
block gaurd
and standalone
revhard turbo kit
Now i don't even know if 7k will get me the option two or not. But which would be better, and what is going to be the difference between the two...Pros and Cons kind of thing.?
or should i do an option three and do the b18c with rods, pistons, lightened fly, clutch, all new valvetrain, manifold, header, fuel system, exhaust and cold air intake and then have to wait another 6 months before i can turbo?
Old Jan 1, 2003 | 07:30 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: different engine options....PLEASE HELP (mitchb)
option 3 dont learn the hard way. patience is the #1 key in building a motor!!!
Old Jan 1, 2003 | 09:39 PM
BudaKai's Avatar
Default Re: different engine options....PLEASE HELP (MotorMatrix.com)
Not to mention a custom set-up would be cheaper, and quite a bit more enjoyable to put together.
Old Jan 1, 2003 | 10:56 PM
I Like Boost's Avatar
Default Re: different engine options....PLEASE HELP (tzsir)
if you wanna spend alot of money to go very very fast and reliable i'd go option 3. but don't waste any money on all-motor parts (e.g. cold air intake, header, ect.) get a b18c, get the block bored and sleeved. pistons, rods, ect. break in the motor until you've saved anythere 3-4k for turbo parts/accessarys
OR
Stock b18b, turbo kit, hondata - cheaper but still very fast for the street
center66ljk
May 13, 2016 06:12 PM
92 civic VX B18c
Jun 14, 2003 09:10 AM
turbopanda
Sep 16, 2002 12:11 PM
