Different between tony1 setup and prostreetonline
Old Jul 18, 2005 | 02:42 PM
The Jacko's Avatar
Default Different between tony1 setup and prostreetonline
I was wondering what is the difference in tony1's Distributorless setup and prostreetonline.com setup
http://my.prostreetonline.com/...eid=4
Old Jul 18, 2005 | 04:29 PM
Full-Race Geoff's Avatar
Default Re: Different between tony1 setup and prostreetonline (The Jacko)
tony1 uses motec, the thing you posted to uses AEM
Old Jul 18, 2005 | 04:32 PM
done's Avatar
Default Re: Different between tony1 setup and prostreetonline (Full-Race Geoff)
is it possible to setup a dual or single coil pack with hondata?
Old Jul 18, 2005 | 06:34 PM
The Jacko's Avatar
Tony1 setup can be used with aem
Old Jul 18, 2005 | 06:54 PM
tony1's Avatar
My setup is the input signals from the distributor, allowing you to completely remove the dist. once an individual coil ignition system is installed, which is what that is, and what anybody can provide. Their system still uses the stock dist. signals for triggering, which are the main thing you're trying to get rid of. For an individual coil ign system, you just buy a 4 channel ign box and some coils, there's not much of a "kit" to it.
Old Jul 18, 2005 | 07:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Different between tony1 setup and prostreetonline (tony1)
lets say im running an obd1 aem on an obd2 motor.... then what?
Old Jul 18, 2005 | 07:12 PM
The Jacko's Avatar
I have aem ems and msd dis2 does your setup work with this
Old Jul 18, 2005 | 07:29 PM
tony1's Avatar
Default Re: Different between tony1 setup and prostreetonline (wantboost)
With my setup it doesn't matter what series B motor you're running. It completely removes the dist. and changes the signals coming into the ecu. You have to have an aftermarket ecu with configurable inputs, like aem. It works great on the aem ems, and cures the high rpm misfires that most people have due to bad dist. signals. Motec, Autronic, Haltech, AEM, and many other ecus can benefit from it. Which ignition box you choose is up to you, any of them will work. I guess it's easier to understand the difference if you think about it that this is on the INPUT side of the ecu, and the ignition system is on the OUTPUT side.
Old Jul 18, 2005 | 07:35 PM
wantboost's Avatar
Who is Mr Robot?
have a link to your setup? i cant seem to find it. also, what ignition box do you prefer? also, when it comes time to pop my oem obd2 ecu and everything back in, is this setup easily removeable so the car runs off of the dizzy again?
Old Jul 18, 2005 | 07:46 PM
tony1's Avatar
https://honda-tech.com/zerothread?id=1170475
I recommend M&W ignition boxes, MUCH better quality than MSD, and much more reliable. When it comes time to put the dist. back on, it's just a matter of putting it on and plugging it in. Just depends on how you wire in this sensor. If you used a mating connector for the dist. harness, from an old dist, then you could actually just unplug this sensor and plug the dist. and stock ecu back in.
Old Jul 18, 2005 | 07:51 PM
wantboost's Avatar
Who is Mr Robot?
http://www.we-todd-did-racing....D.jpg
i wouldnt mind doing like that... can you sell just the trigger? and also can you modify my cam gear with the magnets.? i should be running aem and i would like to keep the adjustability of the gears.
Old Jul 18, 2005 | 07:53 PM
tony1's Avatar
I can sell you whatever you need. What kind of cam gear do you have? Most of the ones available won't work, because the outer ring isn't thick enough to install the magnets into. The golden eagle gears are thick enough to install the magnets and retain adjustability.
Old Jul 18, 2005 | 07:56 PM
wantboost's Avatar
Who is Mr Robot?
if i were to do this, id need the sensor and the ignition box and the ge cam gears that have been modified (possibly). could you also modify the valve cover as shown above?
i have aem right now (wel i should if my damn head ever gets here) but i might be swapping over to str;s and some custom comp cams. not to mention a little help setting the aem up
Old Jul 18, 2005 | 07:59 PM
tony1's Avatar
Give me a call at the shop tomorrow and we can talk about details.
Tony
214-607-9022
Old Jul 18, 2005 | 08:00 PM
wantboost's Avatar
Who is Mr Robot?
alrighty. i'll do that... texas is 2 hours behind ga right?
tony1's Avatar
1 hr.
Old Jul 18, 2005 | 08:03 PM
wantboost's Avatar
Who is Mr Robot?
how late are you generally at the shop?
Old Jul 18, 2005 | 08:06 PM
tony1's Avatar
Right now i'm still setting up, so it just depends what's going on. 9-6 or so at least right now. Business hours will probably be 10-7.
Old Jul 18, 2005 | 08:45 PM
Turbocivic94's Avatar
I wish I can do this setup with Neptune. I hate misfiring
Old Jul 18, 2005 | 08:50 PM
tony1's Avatar
Default Re: Different between tony1 setup and prostreetonline (Turbocivic94)
If you are misfiring with Neptune, then it's a different situation more than likely. The honda ecu reads the dist. signals very well, honda put a couple extra hours into designing their ecu to do so. lol The aem ecu seems to have problems alot of times reading the dist. signals cleanly. They will often develop a high rpm misfire because of this. The "misfire" in this situation is usually a result of bad signals into the ecu, while your "misfire" with neptune is probably more of a problem with too much cylinder pressure blowing the spark out. Your solution is a stronger ignition system (assuming the dist. is in good cond.), while a stronger ign. system won't solve the problem of the input signals not being picked up correctly by the aem ecu. Make sense?
Old Jul 19, 2005 | 06:15 AM
Arturbo's Avatar
Better than steak
25 Year Member
If anyone needs a good ignition system we carry the full line of M&W set ups. From the single to a 4 channel. Its so good even motec uses them, but not at the motec price!
art
Old Jul 19, 2005 | 06:32 AM
I think my problem was with distributor so I changed it. I have msd digital 6 with HVC coil. Hopefully they dont give up on me. If my msd goes I'l be hitting u guys up for M&W ignition
1baddcivicsi
May 22, 2010 06:22 PM
h22 civic
Mar 29, 2010 11:43 PM
RedneckRicer
Apr 24, 2008 11:55 AM
cuin9sec
Mar 19, 2007 04:58 PM
tgreaves
Sep 13, 2005 01:01 PM
