DIF. between 35mm, 38mm,tial wastegates
Re: DIF. between 35mm, 38mm,tial wastegates (fastcivicboy)
The differences is the size of the valve / opening. The bigger the wastegate the more exhaust gas it will be able to let out quicker.
Re: DIF. between 35mm, 38mm,tial wastegates (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">The differences is the size of the valve / opening. The bigger the wastegate the more exhaust gas it will be able to let out quicker.</TD></TR></TABLE>
what he said yup the only difference is the valve the design principles are the exact same
Re: DIF. between 35mm, 38mm,tial wastegates (b18bturbo)
So what do you use to determine the difference between when to use a 35/36mm and a 38mm+?
Is it the amount of power you're pushing? For instance a Deltagate wastegate on an 220whp car? Would you use a 36mm over a 38mm or is it actually better to use a 38mm?
Re: DIF. between 35mm, 38mm,tial wastegates (h23sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23sleeper »</TD></TR><TR><TD CLASS="quote">So what do you use to determine the difference between when to use a 35/36mm and a 38mm+?</TD></TR></TABLE>
there's no 36mm
there's no 36mm
Re: DIF. between 35mm, 38mm,tial wastegates (oxSLEEPERxo)
oh yea, i forgot, tial 35mm is discountinued, but you can pick up a used one from time to time, kind of rare to pick up a brand new one, unless its a ssac crap
IT'S ME DAVID
11-01-2006 10:36 AM
CrazyHB
10-25-2004 08:47 PM
BoostedGSRBubble
07-14-2004 04:58 PM
