Smoke out the breather but good compression?
Old 03-26-2005, 03:40 PM
.David's Avatar
Default Smoke out the breather but good compression?
I got my car tuned yesturday, and noticed a lot of smoke coming out of my breather filter. I checked my compression today and I have 120 across the board (same as its always been)
Am I ok or is there a problem with my car? Its a stock block boosted d16
Old 03-26-2005, 03:57 PM
GDM Z28's Avatar
Default Re: Smoke out the breather but good compression? (TurboDaveR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDaveR &raquo;</TD></TR><TR><TD CLASS="quote">I got my car tuned yesturday, and noticed a lot of smoke coming out of my breather filter. I checked my compression today and I have 120 across the board (same as its always been)
Am I ok or is there a problem with my car? Its a stock block boosted d16</TD></TR></TABLE>
ummm..120 seems very low to be buddy.....but they are consistant so thats weird.....
Old 03-26-2005, 04:04 PM
s2kdre's Avatar
Default Re: Smoke out the breather but good compression? (civicflnum1)
you can perfect compression numbers with messed up ringlands. Not alot of people no that.
Old 03-26-2005, 04:17 PM
hondapreludejay's Avatar
oil smoke or coolant smoke?
Old 03-26-2005, 05:26 PM
nonvtecD's Avatar
120 is like 7:1 compression, those rings are hurting.
Old 03-26-2005, 05:42 PM
.David's Avatar
im assuming my high altitude effects comp numbers because thats what my gauge has read since day one, about 10,000 unboosted miles ago.
Old 03-27-2005, 07:50 AM
GDM Z28's Avatar
Default Re: Smoke out the breather but good compression? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">you can perfect compression numbers with messed up ringlands. Not alot of people no that.</TD></TR></TABLE>
that is true at a local SRT shop there were 2 SRT's that had PERFECT comp and they tore down the motors to build them and we found broken ringlands on both motors....
Old 03-27-2005, 07:51 AM
GDM Z28's Avatar
Default Re: (TurboDaveR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDaveR &raquo;</TD></TR><TR><TD CLASS="quote">im assuming my high altitude effects comp numbers because thats what my gauge has read since day one, about 10,000 unboosted miles ago.</TD></TR></TABLE>
try another gauge....ur gauge may be hurting...same thing happen to a buddy of mine...we did a comp. check on his CTR motor and it came back 170 across so were like "wtf" n bought another gauge then it gave us like 250 across or something up there....try another gauge.
Old 03-27-2005, 11:24 AM
.David's Avatar
hmm, alright. Im just gonna save up for some forged internals just incase my motor is about to blow. If worse comes to worse I will just end up with a semi build block.
Old 03-27-2005, 11:32 AM
boosted_b16a's Avatar
altitude has no effect on comp. #'s,i'm at 5000 ft. elevation and my b16 has perfect 195 psi across the board!
Old 03-27-2005, 12:52 PM
chingo's Avatar
sorry to break it down buddy, your ring lands are gone.
messure your oil level, because that smoke you see is oil burning.
Old 03-27-2005, 01:07 PM
GDM Z28's Avatar
Default Re: (boosted_b16a)
my 9:1 ls/vtec puts out 190psi......urs sound alittle low since all my friends b16's put out over 200
Old 03-27-2005, 02:17 PM
Civicman86's Avatar
Default Re: (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">try another gauge....ur gauge may be hurting...same thing happen to a buddy of mine...we did a comp. check on his CTR motor and it came back 170 across so were like "wtf" n bought another gauge then it gave us like 250 across or something up there....try another gauge.</TD></TR></TABLE>
Same thing happened to me
Old 03-27-2005, 09:05 PM
unclepowers's Avatar
Default Re: (Civicman86)
monitor ur oil levels n consumption closely, cuz u might have a problem with some of ur rings...
vipokc
02-04-2009 06:57 AM
H.A.R.T B18C1EG6
07-10-2006 08:22 AM
tpdc2
07-08-2006 02:29 PM
Froggin
01-04-2005 05:22 AM
VNTEC
05-22-2004 08:23 PM
Quick Reply: Smoke out the breather but good compression?
