Diagnose my Problem!!
Old Aug 18, 2004 | 02:01 PM
2muchPSI's Avatar
Default Diagnose my Problem!!
Well, the time has come for me to go back to school in a week. I just got a new clutch in my car, broke it in gently, and discovered this huge problem. My car has no power at all anymore, it is boosting fine, no boost leaks, etc. just not going anywhere. Well I compression tested it today, and it came out 135-135-150-175.
I have dissapearing coolant, white spark plugs, all the normal symptoms of a blown head gasket. 2 months ago the motor compression tested at 180 across the board. Does this sound like a head gasket to you? I just replaced it with oem and arp studs 3 months ago.
The motor is a D16y8, crower rods, JE pistons 9:1, built head, blockguard, T3/T04e .63, running uberdata
Can a cracked sleeve cause compression loss in all cylinders? or is it even possible to crack all the sleeves at once?
Please help, I'm getting fed up with this car, and only have a couple days to get it fixed for college. Thanks!
Old Aug 19, 2004 | 04:16 AM
2muchPSI's Avatar
Default Re: Diagnose my Problem!! (2muchPSI)
help me out guys, I'm running out of time
Old Aug 19, 2004 | 04:32 AM
ek_99_SiR's Avatar
ya go get a head gasket and arp head studs
Old Aug 19, 2004 | 06:19 AM
2muchPSI's Avatar
Default Re: Diagnose my Problem!! (1.6i-16zc)
the motor has arp studs in it, and an oem gasket I just replaced 4,000 miles ago
Old Aug 19, 2004 | 07:53 AM
norcalcrx's Avatar
When you replaced the gasket and studs did you check the head and block to make sure they werent warped?
Old Aug 19, 2004 | 08:15 AM
2muchPSI's Avatar
Default Re: Diagnose my Problem!! (norcalcrx)
the head was checked, but the block was not
Old Aug 19, 2004 | 08:18 AM
RA166E's Avatar
I would do a leakdown to check to see if you have cross over.
Old Aug 19, 2004 | 11:12 AM
2muchPSI's Avatar
Default Re: Diagnose my Problem!! (RA166E)
Yeah, I'm doing a leak down check tonight, what do you mean by "cross over" though?
Tong.Y
Jun 5, 2011 09:17 PM
ONESICKFERIO
Feb 11, 2010 06:28 PM
JDubbs99Civic
Jun 7, 2005 09:19 AM
cstay
Apr 11, 2004 08:27 PM
crxONcrack
Mar 17, 2003 08:36 AM
