Detonation Problems!
Old Dec 10, 2001 | 11:49 AM
Chuji's Avatar
Default Detonation Problems!
Ive been running this setup for almost a year and never had a problem but now I think im getting detonation for some reason. Everytime I hit 7lbs I feel a major drop in hp, at 6lbs it boosts fine. Im using the endyne modified bosch and a vortech 12:1 FMU for fuel. Timing is at 14. I think my Vortech FMU is broken because I tried retarding the timing even more and I felt power loss as soon as it started boosting. Any suggestions?
Old Dec 10, 2001 | 11:58 AM
98Psi ITR's Avatar
Default Re: Detonation Problems! (Chuji)
you check your plugs? O2 sensor? diaghram on the vortech?
if you need that vortech unit, I have one used with the 12:1 and 8:1 diaghram.
Old Dec 10, 2001 | 12:04 PM
Chuji's Avatar
Default Re: Detonation Problems! (98Psi ITR)
The plugs are fine and im running an open downpipe right now with only 1 O2 which seems to be working fine on the A/F meter. How do I check the FMU?
90AcuraIntegra04
Mar 1, 2006 04:56 PM
slowpokesi
Nov 6, 2004 04:14 PM
kovert
Aug 17, 2004 09:58 AM
Nameless RB26
Feb 21, 2004 01:46 PM
turbotec
Mar 1, 2002 04:27 AM
