detination and timing issues?
Old Nov 8, 2005 | 08:59 PM
boosted-EG6's Avatar
Default detination and timing issues?
hey im new to honda tech and to the turbo secne. but i have been on the all motor secne for quite awhile but i just boosted my b16a2 in a civic HB and i can only retard my timing by 3 degree's on the timing gun i run a unorthadox full race underdrive pulley and my pops and i cant figure out why we cant get it to go any higher need sugestion's bad thanks
Old Nov 8, 2005 | 09:21 PM
vaporboy12's Avatar
Default Re: detination and timing issues? (unleashedhonda)
first off put your stock pulley back on if you like your oil pump and bearing and then go from there
Old Nov 8, 2005 | 09:35 PM
thanks man i told me dad that i think it might help if i put my stock one back on but i will try that tomorrow and ill get back to you about and if there is any other suggestions just drop a few lines thanks.
Old Nov 8, 2005 | 10:31 PM
YiNYaNg's Avatar
Post up in detail what your setup is and we can start from there.
Old Nov 10, 2005 | 11:13 PM
Default Re: detination and timing issues? (H-T)
hey well i have a t3-to4e turbo 50-63 a/r with the unorthadox full race pully. and im running 2.5 in I C piping with a strait down pipe no O2 for right now, and i have a set of rc 310 injectors with a str fuel rail along with a adjustable fuel pressure regulater and the wastegate has a 9 Lb spring in it along with a raptor blow off valve and a front mount intercooler and jdm type-R cams and msd 6al and ext blaster 3 coil. i need the help bad i want to keep this motor alive during winter.
Old Nov 11, 2005 | 06:30 PM
YiNYaNg's Avatar
Default Re: detination and timing issues? (boosted-EG6)
What EMS (Engine Managetment System) are you using to control those injectors?
Old Nov 14, 2005 | 08:35 PM
well before i used 310 injectors on a vafc now im running a set of 550
Old Nov 14, 2005 | 08:41 PM
.dave's Avatar
i HAS questions ?
You need something to control the timing on that thing.
Check out http://www.pgmfi.org for freeware ECU chipping. Its a good place to start regardless of what direction you decide to go (Crome, Uberdata, Hondata, Neptune etc...).
Old Nov 14, 2005 | 11:05 PM
Lenne's Avatar
I have a h22 on 14 pounds...
no detonation after i got a
AEM fuel rail and fuel pressure regulator
and a walbro fuel pump...
i still need a good tune tho...
a good tune will fix most problems
like detonation
vtec8200
Aug 25, 2010 10:50 AM
Running925
Oct 22, 2007 10:13 AM
importtuner07
Aug 9, 2006 10:51 PM
notstock93
Sep 27, 2004 02:07 PM
